Coolant leak!!
Old Feb 7, 2008 | 04:37 PM
Mills's Avatar
Default Coolant leak!!
My coolant is considerably low (I think its a slow leak) , the closet Audi dealer is over 40 miles away, so getting the Audi coolant ( G-13 is that what its called??) is out of the question. Should I either just fill her up with distilled water or get brand X coolant until I can get the leak fixed?
Thanks for the input guys
Old Feb 7, 2008 | 04:53 PM
audiS4jls's Avatar
Default RE: Coolant leak!!
It's G-12. You can get some at VW Dealerships also.
I would stay away from other brand coolants.In time, it can bevery harmful to your engine. You're probably better of using water.
Old Feb 7, 2008 | 06:25 PM
daness373's Avatar
I would say use brand x JUST untill you get till the dealership... So your 40 mile trip only. Its better than water. I have had this experience before, and this is what my mechanic told me to do. thanks, Scott
Old Feb 7, 2008 | 09:33 PM
TKneedsS4's Avatar
its the aux tank prolly has the usuall crack in it. just need to replace it fairly simple. umm yea only use g12 and i guess use either or distilled or xbrand but flush it immmediatly when u get the good stuff
Old Feb 7, 2008 | 09:36 PM
deephouse's Avatar
ORIGINAL: audiS4jls
2nd. It wont hurt to thin out what little coolant is left in the system with regular H2O.
40 miles isn't a bad drive. Keep the RPMS low.
Then, buy enough G12 for a full coolant flush.
Drive home and flush it out, refill. done.
Old Feb 8, 2008 | 12:00 AM
Mills's Avatar
Thanks for the info. guys
The closest VW dealer is even further then the Audi so, looks like I am stuck going the 40 + miles to the Audi
Old Feb 8, 2008 | 01:36 AM
Batteries's Avatar
Since this is on topic, I have a question.
Is G-12 really NECESSARY? I always see it recommended exclusively, and everyone here swears by it like their radiator will explode if a drop of "generic" gets in the tank. Is there evidence that other brands have caused failures....?
If you look at a bottle of the "revised" Prestone green coolant, it says that it is 100% compatible with ANY make and model. It even *guarantees* that you can mix it with *any* color antifreeze currently in the car, without facing any consequences.
I mean, I'm all about using OEM as much as the next guy. For example I'd never, ever use a non-Mann OEM oil filter, or generic non-synthetic oil, because these are explicitly recommended by Audi, but why all the fuss about G12.........?
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
supacor24
Jun 3, 2011 07:56 AM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
