AudiForums.com
-   S Car Model Line (https://www.audiforums.com/forum/s-car-model-line-13/)
-   -   fault code (https://www.audiforums.com/forum/s-car-model-line-13/fault-code-115422/)
JohnnyS4 Oct 12, 2008 12:43 PM
fault code
p1131 b2 s1 = this is passenger side front o2 sensor correct? I did a search but really didn`t find an answer. I started getting this code ever since I installed my new exhaust.I dont see anything wrong with the wiring.
meatbiscuit Oct 13, 2008 12:51 AM
Yah P1131 is the driver's side primary, just behind the coolant reservoir and back underneath the firewall. Have fun replacing it, it's a whore. I found it much easier to remove the Y-Pipe and get several extensions along with a U-Joint to remove it.
I had the same code and replaced mine with a 4-wire universal, so far it's been working great. It's a lot cheaper than buying OEM.
JohnnyS4 Oct 13, 2008 10:02 AM
ok its the drivers side, i thought it was the passenger side. thanks for your help.
