First Post and Vag Code Help
Old Jan 15, 2008 | 01:41 PM
rycar550's Avatar
Default First Post and Vag Code Help
I bought a 2000 S4 6 speed in September, and ever since have been on this forum nonstop. The car is stock besides Stasis Track Sports and JHM shifter. But anyways this is my first post. I have a check engine light on that I just check for codes. The codes are
17861 Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus P1453 - 35-10 -- Intermittent
16805 - Shareware - P0421
16815 - Shareware -P0431
Ok, so after searching the forum, I have found that most likely I need to replace one of my EGT sensor and that my cats are bad (time for piggies?).
My Question is, is there another issue that could be causing these codes. I thought it would be strange that both P0421 and P0431 would appear at the same time. I just dont want to replace parts when it is not the real issue.
Also, Is EGT sensor 1 the passenger or drivers side?
It may also be good to tell you that the other day the car was jumpy when pressing the accelerator and letting go of the accelerator sporadically which could be a sign of a bad EGT sensor it think.
Any help on next steps here would be most appreciated.
Ryan
Old Jan 16, 2008 | 02:15 PM
2k S4's Avatar
Default RE: First Post and Vag Code Help
You have been here non stop, but this is your first post?
I would change out the EGT & go from there, my bet is you have other problems, & yes, both cats can be bad, & this can also cause a EGT fault.
Old Jan 16, 2008 | 02:25 PM
techbod's Avatar
P1435 is your problem ( secondary air injection (APR) short to ground ) possible fix = wiring short to ground, AIR pump relay
Old Jan 16, 2008 | 03:55 PM
rycar550's Avatar
thanks for all your help so far.
Ryan
Euro Dreams
Dec 6, 2019 03:38 AM
barney12
Oct 20, 2019 03:30 AM
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
