Funny squeak thats not so funny
Hey everyone I'm new here but have gleaned a bunch of info from all the other posts and am very thankful for every one's opinions and hope to get some more from you guys now. I have a 2002 S4 and I've had it since januaury this year and it has been a great car, but I just discovered something pretty annoying. A squeak has developed thats sounds like the brakes need to be changed, but it only happens when I'm driving and NOT braking. When I do hit the brakes it stops. Needless to say I'm pretty confused and would appreciate any help you can offer. Thanks in advance
RE: Funny squeak thats not so funny
hey i just bought an b5 s4 also so i dunno if the brakes have it, but on my last car when the brakes got too worn there was a tab that would make a noise like that to tell you you needed new brakes and obviously once pushed down on it would stop... to me that sounds like what it is.
^^^^^^ hahahahaa....bunches of newbies....j/k.....the S4 come with brakes sensors...if is low it will show brake CEL...but "its4her", if you said exactly the way is it....i think it could be the brake pad(s)...some aftermarket pads mite do that... making squeaky noise at low speed while going over bumps but stop when you step on the brake...thats what happen to mine....if not then it could beanything...suspension, tie rod, a-arm....good luck
Thanks guys for the input guys. Does anyone know of a place close to temecula CA where I can have the work done? I know I can take it to anywhere that normally does brakes, but I'd rather take it somewhere with a good reputation. Thanks for the info
That was pretty funny techbod Actually it looks like the brakes are making the squeak. I had a look at the rear pads and they are worn down pretty good and it looks like all the rotors are kinda lumpy which sucks So this may be a good time to upgrade the brakes a little. Does anyone have any suggestions on some aftermarket pads and rotors that you guys prefer? I want to kick up the stopping power without spending a bunch on a whole brake kit. And I also found something else that looks bothersome... It seems as though there is some sort of grease flinging around the front driverside wheel well, any ideas what that might be? Thaks again for the info
RE: Funny squeak that's not so funny
there is a difference between a squeak and a scrape, when the pads are worn you hear a metal to metal noise and that means pads and disks/rotors but in most cases it means the system wasn't serviced right and all moving parts were not cleaned and copper slipped/greased
