help with CEL p1370
Old May 24, 2010 | 04:57 AM
sey1290's Avatar
Default help with CEL p1370
So about two weeks ago i threw CEL p1370, and i believe thats Cyl. 6, ignition circuit Open Circuit. That lead me to believe it was a bad ignition coil. Well instead of buying a new coil and putting it in place, i switched cyl 6 and cyl 4 ignition coils to see if i threw a different code. After clearing the code and driving around for a little, i threw the same code p1370. I changed all the spark plugs since it was about time anyway, and again cleared the code. Once again p1370 came up.. any ideas?
[edit]
should probably mention i drive a 2001.5 b5 audi s4 2.7t.
its currently bone stock for the most part, just bolt ons at the moment, still no tune =\
Old May 24, 2010 | 08:57 PM
sey1290's Avatar
wow 35 views and no response.. this forum is a joke.
Old May 24, 2010 | 09:22 PM
blue0453's Avatar
I no how u feel, and agree this forum is a joke.
Old May 25, 2010 | 03:22 AM
sey1290's Avatar
blue, if u hav an s4, plz join s4 forum, at least there people try to help
Old May 25, 2010 | 07:35 AM
bigern45's Avatar
try swapping icms, and see if the misfire goes to another bank, cylinders 1,2 or 3.. and you could have a break or short in one of the wires going to the coil pack as well... get a test light and see if the coil is getting ground, juice and fire command..
and i agree, i used to be on this forum all the time, and now im on audizine regularly. much more tech support and turbo builds and everything.. just a bigger community altogether ..
Old May 26, 2010 | 03:27 AM
sey1290's Avatar
did all that.
tried changin the ignition coil to all 6 cyl. so far... throwin codes p1370 and p0300 now.
i read all possible solutions to these codes and still wont fire right..
