HELP!!! mass air flow QUESTIONS?
so how much power can the stock maf handle and can it be blowen threw like have it after the turbo instead of in front? im making a new set up with a fmic 2 in 1 out style and i will be making a pipe like the bi pipe for apr but it will be a single 3in pipe instead of the two
RE: HELP!!! mass air flow QUESTIONS?
It can handle more CFM then the K03's can produce.
Yes, you "should" be able to put it on the charge side, but I would be carful, the temp will totally throw off the readings, & you will have to watch the A/F & adjust it with LEMI. |
k thanks
