Hi octane Gas
Old Aug 2, 2005 | 02:54 PM
audilover04's Avatar
Default Hi octane Gas
So I know that many companies make chips with special programs to be run when you use high octane gas i.e. 93, 95 or higher. And they say that the high octane gives you improved HP. But will this hold true without a chip, in my stock B6 S4? Reason I ask is I am using 91 now but a new station opened near work that sells 93 and its not much more expensive.
Old Aug 2, 2005 | 04:40 PM
Frost GST's Avatar
Default RE: Hi octane Gas
It would not give you any more power than you have now. The reason the chips "need" the higher octane fuel is because they go more aggrissive with the air/fuel mixtures, timing, and boost levels. The higher octane fuel helps keep detonation under control.
Hope this helps.
Andy
Old Aug 2, 2005 | 04:52 PM
thanks you just saved me a few bucks, I wont fill-up 93 anymore
Old Aug 2, 2005 | 08:54 PM
WillWorkForS4's Avatar
Frost is correct. You actually make the most power using the lowest octane fuel that your car is tuned for. A friend of mine runs his best times on his Hayabusa on 87 octane (and not the oxygenated stuff, either.)
Peter
Old Aug 4, 2005 | 03:08 AM
jaybquick's Avatar
ORIGINAL: Frost GST
Hope this helps.
Andy
I can attest to that. Get a chip that has multiple settings. With 104 in my tank vs 91 it is the same is Superman vs Clark Kent.
2000a4quattro
Mar 2, 2014 04:17 PM
beata4
Feb 4, 2008 11:45 PM
Pablo_Ottawa
Jan 25, 2008 09:48 PM
smokeU
Jul 5, 2007 01:14 PM
m5racer
Jul 28, 2006 02:12 PM
