AudiForums.com
-   S Car Model Line (https://www.audiforums.com/forum/s-car-model-line-13/)
-   -   Ignition control module help (https://www.audiforums.com/forum/s-car-model-line-13/ignition-control-module-help-126713/)
kiellish Mar 4, 2009 09:18 AM
I'm having issues with these parts on my 2000 S4. My car was running really poorly at idle, chugging, but running fine at any rpm over 2000. Yesterday, I replaced one module (what I thought to be the bad one) and it immediately corrected the idle problem, but created a mid-range and upper rpm shake/shudder while driving under 30% + load. I swapped the modules around and nothing corrected it.
I started it this morning and the same idle problem is back. I always have misfire issues with this car, I'm about to park it on train tracks.
Can anyone help me (with the misfire issue)? Is there a way to test the modules? One shows no resistance, the other shows some. I have dielectric grease on the connections. Coil packs are 2 yrs old. Denso iridium and stock plugs tested. No known boost leaks. New turbos. New head gaskets. New everything.
kiellish Mar 4, 2009 02:35 PM
Probably should have been more specific...do you need to replace in pairs? If one is bad and you run the engine with a good one will it damage the good one? Will a bad coil pack damage them?
