My GT build log.
Not sure if I've posted this yet or not, but here's a link to my RS6 build log. Should be done sometime in spring!
http://www.audizine.com/forum/showthread.php?t=253260 |
WooooooooooooooooooooW. I envy you. CLEAN garage/Shop CLEAN WHITE S4. I love it. good luck!
Iv been following it on the zine. Lucky man:cool:
^ yeah I have too , forgot all about this place, lol his car is WAY clean and i want his lift :)
lift isnt that expensive, look it up.... the names right on the side is in the pictures
damnit, i dont want to be angry and jealous, but i am. haha. its a gear heads paradise in there.
Ha thanks guys.
Originally Posted by SourDieselS4
(Post 1047980)
17 Attachment(s)
Here's the setup I'm working on and it should be done within the next little bit. I'll update this first post with new pics as it progresses. This is by no means a complete list and I'll get more thorough later.
Engine: - Custom Exhaust Manifolds - Agtronic Motorsport - 3" V-band Downpipes, Inlets and Turbos modified by Agtronic Motorsport - Garrett GT2860-707160-7's and oil/coolant lines - SMS Performance - TiAL MV-S 38mm V-band wastegates - SMS Performance - eurojet "Kugel" grenade diverter valve - eurojet racing - Supertech Intake and Dual Exhaust Valve Springs/Titanium Retainers/Inconel Exhaust Valves, 1mm Oversize High Temp Stainless Intake Valves, Phoenlic spacers - Issam@034 - Bosch 044 drop-in - Issam@034 - Integrated Engineering Rods - Pete@Integrated - Custom E85 tune - Greg@SSP - 82lb Siemens Injectors, Bosch F5DPOR plugs, 85mm MAF - Greg@SSP - Clutch Masters Stage 4 FX400 6-puck w/ WMS Steel Flywheel - Wicked Motorsports (WMS) - ARD Bipipes - ARDesign - ER SMIC's - SDR X-1 Intake and RS4 accordian - Ebay silicone tubes - 2.8 heads w/ 2.8 cams - RS4 headgaskets - Big EFK - VAST - 034 Track Density Engine/Tranny Mounts, Phoenlic Spacers, Apikol Rear Diff Mount - Issam@034 - Zeitronix Wideband - JHM Hallman in-cabin MBC, SS, Shifter Linkage, Delrin Bushing - JHM - 150 amp 14.8 volt upgraded Alternator "Ultranator" - Avimeron@gmail.com Interior: - RS4 shift knob - B6 Ultrasport steering wheel and TT airbag - Carbon fiber interior trim - Carbonetiks - AWE new vent boost gauge - Pioneer AVIC-f90bt - Critical Mass UL12's - Powerbass XA-3000d Exterior: - Sport Mirrors (or maybe something crazy[:D]) - RS4 grill - 20% Suntek Carbon Series Tint - Depo E-codes - 55W DDM HID Kit - Carbon fiber engine covers (and maybe a couple other parts) This list is only new stuff that I'm adding. Pics: Turbos Garrett 2860-7's (unmodified) Attachment 45811 http://i297.photobucket.com/albums/m...d/P5280231.jpg TiAL MV-S Wastegates Attachment 45812 034 Track Density motor/tranny mounts, Apikol rear diff mount, poly mount for DTS Attachment 45813 Integrated Engineering Rods w/ ARP bolts Attachment 45814 Attachment 45815 eurojet "Kugel" diverter valves Attachment 45816 2.8 Heads Attachment 45817 ARD Bipipes Attachment 45818 Ebay silicone pipes:) Attachment 45819 ER SMIC's Attachment 45820 SDR X-1 Intake Attachment 45821 VAST EFK and tidbits Attachment 45822 JHM Hallman In-cabin adjustable MBC Attachment 45823 Sport mirrors Attachment 45824 RS4 grill Attachment 45825 Depo E-codes Attachment 45826 DDM 55w H7 HID kit Attachment 45827 |
10 Attachment(s)
RS4 Shift Knob
Attachment 45801 B6 S-line steering wheel w/ TT airbag Attachment 45802 Pioneer AVIC-f90bt Attachment 45803 CM UL12's Attachment 45804 Powerbass XA-3000D Attachment 45805 What my front room looked like Attachment 45806 Stage 2+ preliminary baseline dyno (enriching and pulling timing with bad EGT) Attachment 45807 Attachment 45808 Attachment 45809 One of many new tools Attachment 45810 I will update this as it progresses[wrench] Last updated 6/11/09 |
17 Attachment(s)
My shop that I've been cleaning out, prepping, painting and outfitting for the past little bit
Attachment 45784 New 4 post lift! Attachment 45785 Pops helping assemble lift Attachment 45786 Almost assembled Attachment 45787 1/9/09 Well I finally got the lift fully assembled last weekend http://i297.photobucket.com/albums/m...d/P1050017.jpg And took a final shot of the car before I started taking some parts out Attachment 45788 Attachment 45789 2/18/09 Well I started on my engine pull last night cause my motor sold and I bought my new one, so some progress finally! I started around 530pm, pops left around 930-1000pm (we had the driveline/stuff underneath done and the airbox/y-pipe stuff done.) Then I took my time and got stuck at the end trying to figure out how to get the freaking AC compressor out[headbang][evilmad] I was there til after 4am tinkering with it, though I should've left earlier because I wasn't very productive by that time. Anywho, onto the pictures. Onto the motor pull. Before she was touched (except for the headlights that I sold a while back.) Attachment 45790 Where we but the zip-lock bagged bolts Attachment 45791 We had to lift the car with some 2x4's on the DTS because of the way the jack was. http://i297.photobucket.com/albums/m...d/P2160022.jpg Pulling the half-shafts, cat-back exhaust and driveline Attachment 45792 Attachment 45793 Passenger's shaft out http://i297.photobucket.com/albums/m...d/P2160016.jpg Driver's shaft out Attachment 45794 Apparently I had a horribly torn boot since the last time I checked a month or two ago Attachment 45795 Catback off (I have a new found love for v-band clamps!) Taking off Driveline heatshield Attachment 45796 Disconnecting the driveline Attachment 45797 Pile o' parts so far Attachment 45798 From here on I was on my own. Front bumper and fogs off. My RS4 bumper was held on differently than the stock ones from the writeup (other than the two main bumper support bolts of course.) Attachment 45799 IC shrouds and pusher fan off. Draining the coolant (I caught most of the initial drain from the radiator, but when moving the whole radiator/front clip and when unplugging other hoses around the motor I got coolant everywere, over and again!) Attachment 45800 |
