S4 misfire, please help
My stage 2 2000 s4 is having misfire problems. The code is P0300 (random/multiple misfires). I replaced the spark plugs (gapped to .028) and I just replaced all 6 coilpacks and the problem still persists. The car sputters and doesn't have much power. It throws 4 codes which are as follows:
P1118
Manufacturer Control.
Fuel Air Metering
P0300
Random/Multiple
Cylinder
Misfire Detected
P1114
Fuel Air Metering
P0140
O2 Sensor
CKT No Activity
(Bank 1 Sensor 2)
I'm thinking either MAF or 02 sensors but please give input
Thanks,
Klaus
P1118
Fuel Air Metering
P0300
Random/Multiple
Cylinder
Misfire Detected
P1114
Fuel Air Metering
P0140
O2 Sensor
CKT No Activity
(Bank 1 Sensor 2)
Thanks,
Klaus
do the maf.. the o2 code is a catalyst monitoring code and has nothing to do with drivability.. the maf can be reading way off and cause the ecu to command rich or lean, and that will cause a misfire, your p0300 code...you could also have a vacuum leak which could cause a maf code.. id replace the sensor though....
and so what do the plugs have to do with the air fuel metering code?? nothing.. start with the maf.. smaller gap def is better, especially if your running a stage 2 tune..
Russ Heinrichs
08-18-2021 12:39 PM
A4ENGRSF
10-09-2010 09:49 PM
