Tbb help!!!
Old Sep 4, 2008 | 03:00 PM
lilnickx69's Avatar
Default Tbb help!!!
hey so i just got done installing the samco tbb and i test drove the car and it feels kinda sluggish. I dont know if maybe the car has to be warmed up or im just thinking that the car is supposed to drive faster (im not sure), anyways i made sure the tbb was secured around all the hoses so that no air could get out and when i was installing it i moved one of the pipes and i heard something crack and fell on the floor but when i went to go look for it there was nothing there.
If the tbb wasnt on properly would the car be a LOT slower that you would be able to tell?
Any other symtoms that you might be able to tell if its not on properly??
help!!
Old Sep 4, 2008 | 03:40 PM
readimag's Avatar
you might have cracked the plastic hose from tbb, to the intercooler upper hose look for a leak.
Old Sep 4, 2008 | 09:12 PM
lilnickx69's Avatar
how would i go about looking for the boost leak?
Also would the change in power be enough so you could be able to tell. Becuase when i floor the car it seems to be driving normally how it usually does.
Old Sep 4, 2008 | 10:00 PM
readimag's Avatar
yeah if you have a leak you will know the car will just fall flat on its face.
Old Sep 4, 2008 | 10:32 PM
lilnickx69's Avatar
Oh ok so i probably dont have a leak and did the tbb install right?
becuase my car seems to be driving like it was normally.
Old Sep 4, 2008 | 10:49 PM
Rajan147's Avatar
you may have just stressed or cracked the plastic where the bipipe attaches to the timing cover. its pretty tight down there.
if your samco tbb isnt installed properly you will have issues getting the car to higher RPMs and building boost.
Keep and eye on your boost gauge and also periodically check it, especially the underside to make sure that everything is snug.
My tbb was loose at the bottom, i didnt throw a CEL and i couldnt get past 4k rpms.
Old Sep 4, 2008 | 10:55 PM
Rajan147's Avatar
Old Sep 4, 2008 | 11:14 PM
lilnickx69's Avatar
My car has no problem getting up to to the redline at all and it drives like it normally did (when i floor it or just accelerate). My question is though if something was wrong Ie: a boost leak, would i be able to notice it.
Like would my car be like a turtle?
Old Sep 4, 2008 | 11:20 PM
Rajan147's Avatar
it depends on how big of a boost leak. A big enough boost leak can throw the car into limp mode.
If you don't have one already get a boost gauge. its going to your first line of defense. Also you can make a pressure tester (see www.awe-tuning.com for details).
Old Sep 4, 2008 | 11:26 PM
lilnickx69's Avatar
well my car runs like it did when i originally got it so im kinda confused. Even if there is a moderate boost leak wouldnt you still be able to tell?
