Types of N75's
Old Nov 2, 2008 | 05:27 PM
b5hobsons4's Avatar
Default Types of N75's
Can someone please tell me the difference between the race N75 and the other types or give me a link to a thread about it.
Old Nov 2, 2008 | 06:24 PM
b5hobsons4's Avatar
Or whether I should just buy a stock n75 and put it on.
Old Nov 2, 2008 | 09:25 PM
RED_01's Avatar
http://www.ecstuning.com/stage/edpd/...&productID=122
You'll probably want to go stock so you can be sure your comparing 'apples to apples' when you swap them.
That way you don't create any new symptoms.
I only say this because I have a race n75 but I have to run an mbc in parallel to prevent a 22 psi spike at low rpms, that triggers the throttle cut.
It is good for 2-3 psi at the low-mid rpms though. But it doesn't affect boost at the top end.
I should also mention that the race n75 worked fine without an mbc when I had just the k03s with an APR 93 oct. tune.
Old Nov 2, 2008 | 09:47 PM
b5hobsons4's Avatar
That's what I kinda figured, but I wasn't sure if there would be any plus to get a race valve over the stock valve. I hear a lot of good and bad with the race. Is there any performance difference between the stock and race? I don't want it to let the boost spike because I think that is my problem right now.
rahip4567
B8 Models
Nov 12, 2012 08:47 PM
kovalchuk71
Feb 24, 2007 01:50 PM
audiprotein
Oct 8, 2006 03:08 AM
skippster86
Nov 2, 2004 04:14 PM
