Warped Rotors cause vibration when not braking?
Can warped rotors cause a vibration when not braking?
Also, what would cause the car to vibrate at any speed? The vibration varies with speed, slower speed the less vibration, higher speed the more vibration. |
i would think not.. possibly a joint in an axle or perhaps a tire out of balance or belt slipped on the tire...
I think a warped rotor would cause vibration while braking. Just think about what the rotor does when braking... spins through a caliper... if its warped, then the spinning is not uniform and would cause vibration. and as for the vibration at any speed, get your tires rebalanced and then see if the problem is still there.
Swapped wheels with another set I had and still had the vibrating. So I'm gonna take it in to a shop and get it fixed. I'm tired of trying to get this fixed.
The rotors are definitely warped since whenever I stop it shakes. I understand that, its kind of a no brainer. I was just wondering if maybe the warped rotor would cause a vibration while not stopping. The calipers could possibly be hanging up on me causing a vibration. This got a lot worst after slamming on the brakes a couple weeks ago for a deer. Which in the end hit me anyways. |
Yes.. rotors can cause vibration will not braking....
what about your tie rods? are they the stock ones?
I'm not sure about the tie rods. But the vibration doesn't move the steering wheel very much at all. I mainly feel it in the seat. And I swear I feel it in the rear.
Originally Posted by Midniteoyl
(Post 1091186)
Okie dokie...
If they are warped beyond the 'norm', they with vibate.. Just happened on my truck. These things were so warped they rubbed with the cylinder completely compressed... Once you hit the brakes and reduced that space to close to nothing, well, it wasnt fun. |
Hmmm, well I've gone over the car looking for something wrong with it and I can't find anything. None of the control arms seem loose. No play in driveshafts. CV Joints look fine. Wheel bearings were just changed a month ago. Swapped wheels to see if it was balance issue and I concluded it wasn't. My dads A4 had a bad tie rod and it mainly dealt with vibrations in the steering wheel when turning. Mine are vibrations in mainly the car, with the typical steering wheel vibrations. This only got worst after I slammed on my brakes before a deer hit me. I'm just going to take it in to a euro shop and see what they come up with. I'm stumped, and I hate being stumped and having to take my cars in. Argh.
| All times are GMT -4. The time now is 09:29 AM. |
