Water Pump
Old Sep 9, 2011 | 07:09 PM
audiS4jls's Avatar
Default Water Pump
Looking for some input from you guys.
I'm not much of a grease monkey, and never seem to have the time to learn how to take care of my engine. So... I have to submit myself to the mechanic, unfortunately.
Anyway, I got my timing belt job done around 30k miles ago and now my coolant is leaking.
Whether this is due to my A/C being broken due to a very very hot summer, I don't know. But my coolant is leaking and after being looked at by the mechanic, I need to get my thermostat, water pump, [serpentine belt], electric water pump (probably auxiliary water pump) and hoses replaced.
They want to charge me $2400 to get this all done and I want to know what you guys think. Am I getting jipped? Can I get away without replacing all these parts?
Any help would be appreciated.
Old Sep 9, 2011 | 07:58 PM
02A6Beau's Avatar
not really. they are all in the same area and require the same horrendous amount of preparation work to get at. It is best to have it all replaced at the same time while the car is apart. Did they not replace this when your timing belt was done?
they are probably quoting you the "book" labor. it should take less hours than to book says so the estimate of $2400 is probably pretty high. Is this at a dealership service center or an independent shop? I would shop around to some other places. Prices at indy shops can vary by quite a bit. I'm assuming your car has the 2.7T? If so $2400 is probably about double what I would consider reasonable.
-not an expert, just an enthusiast
Old Sep 9, 2011 | 11:56 PM
audiS4jls's Avatar
All, except for the auxiliary pump was replaced 30k miles ago... I'm surprised it's leaking and so soon.
Old Sep 10, 2011 | 09:49 AM
audiS4jls's Avatar
Ok, so it's the electric water pump, not the auxiliary water pump.
Man, I'm so confused.
Old Sep 10, 2011 | 12:07 PM
02A6Beau's Avatar
the water pump is at the front of the engine and driven by the timing belt
the auxilary coolant pump is on the rear of the engine and is electrically powered
THIS should help
Old Sep 18, 2011 | 08:26 AM
bigern45's Avatar
the electric water pump can be replaced or even bypassed altogether just by removing the intake manifold, something i can have off in 30 minutes. id ask the tech specifically "what is leaking on my car, which water pump, or is it both water pumps..."
aux water pump leaking is very common. he may just want to do t-belt water pump and thermostat for more work or to cover his ***.....
Old Sep 18, 2011 | 07:56 PM
audiS4jls's Avatar
I ended up just getting them both taken care of. They said that both pumps were leaking so I just went for it. As much as i didn't want to, the sound of two water pumps leaking scared me.
Old Oct 12, 2011 | 12:41 AM
bigern45's Avatar
not only would it scare me but the chance of them coincidentally going bad at the same time is amazing. he took you. probably just secondary pump.
sleep well knowing you should be covered for a few years. any other coolant leak from here on out should be turbos.. so thats not a big deal..
clowninmd
S4
May 30, 2013 10:47 PM
MetalMan
Jul 19, 2012 09:15 PM
josh_easlon
Feb 24, 2010 04:32 PM
AUDIFIELD
Oct 28, 2009 03:20 PM
guru_king423
May 20, 2008 08:21 PM
