Will SEVAS S15 WHEELS 19X9.5 fit a B5 S4?
Will SEVAS S15 WHEELS 19X9.5 fit a B5 S4? thanks
RE: Will SEVAS S15 WHEELS 19X9.5 fit a B5 S4?
no, only because i think 19's are pointless
ok...Ur Gay!
Battle!!!!!
What offsets do they come in? if u get the 19x9.5 you will rub HARD when turning if u get 38ish offset they will prolly clear the brakes but the 9.5 will make them rub..... if u find a 9inch or 8.5 it would be much better. 9 might still rub but not much. |
I don't think they will fit unless you run a huge spacer but that isn't recommended.
9.5 with any resonable spacer still will rub.
sorry the SEVAS S15 and S-Start wheels come in +35 offset and are 19X8.5 not 19X9.5
not sure about the offset but I will double check tomorrow....thanks |
bump
well if you can get about a 38 offsett you prolly can get away with no spacer or anything with a 8.5 wide. the only other thing you might need to look at if you got a good drop is your fenders.... they might need to be rolled. but i think if u find a 38 off with 8.5 wide you can fit it
not a chance... the sevas for starters wont fit, yet alone with a 9.5 width.
