AudiForums.com
-   S5 (https://www.audiforums.com/forum/s5-86/)
-   -   Audi S5 Wont Start After Fueling (https://www.audiforums.com/forum/s5-86/audi-s5-wont-start-after-fueling-229496/)
Colton Laidig 12-10-2018 02:40 PM
I bought a 2008 S5 a couple weeks ago, and I've run int o an issue where the car will turn over but wont fire all the way after getting gas. This happens for a couple tries and then fires up fine, and never does it again until I get gas. I replaced the canister purge valve, but that didn't fix the problem. Does anyone know what else could be causing this? The car only has 41,500 miles on it.
hahnmgh63 12-17-2018 03:26 PM
Colton, check the Purge Vent valve. When these fail they give symptoms as yours. Also known as the N80 valve. I have a 2013 3.0t so I am not sure where (most likely engine bay) yours is located. Google search for a pic, all Audi ones look about the same, then look in your engine bay. Do you have Ross-Tech (Vagcom), it should tell if your N80 is throwing a code. Doesn't always set off the CEL if it is intermittent.
Colton Laidig 12-17-2018 04:41 PM
That’s what I thought it would be too, but I replaced the N80 valve and it didn’t fix the problem..
hahnmgh63 12-17-2018 10:01 PM
Might try a fuel pressure leakdown check. After you shut off the engine see how fast the fuel pressure drops. Should stay pretty high for a few hours.
