S5 Cabriolet top not working
Old 02-22-2019, 08:50 PM
cptmrgn's Avatar
Default S5 Cabriolet top not working
Greetings everyone! I recently purchased a 2010 S5 Cabriolet that had been in an accident. the damage was to the driver side door and a little into the quarter panel. I had a friend fix the damage to the car (which was not to bad) and replaced the door with another door. after I got the car back from the body shop the top no longer opened. I can manually move the top into the compartment. at which time the compartment top will open and close by using the switch button in the center console. However, when I attempt to raise the roof, the compartment top does move into the open position but the hydraulic pump in the left of the trunk compartment makes a sound for roughly 15 sec and then stops. I hooked the car up to an Autel and I can see that there are roughly 8 switches for the top in error. they all point to the switches on the left side. some are errors and some say implausible. I do not know where to go from here. Should I break down to buy the Vag-Com? will it tell me which switches are failing? is it possible my friend put things back in the wrong order? could the accident have damaged some of the switches or pinched a wire? Thank you for any help you can give me!
Justin
Old 02-23-2019, 02:34 PM
cptmrgn's Avatar
Default Autel Screeshots
Here are some Screenshots from the Autel on the switch errors
Attached Thumbnails S5 Cabriolet top not working-1.bmp   S5 Cabriolet top not working-2.bmp   S5 Cabriolet top not working-3.bmp   S5 Cabriolet top not working-4.bmp   S5 Cabriolet top not working-5.bmp
S5 Cabriolet top not working-6.bmp   S5 Cabriolet top not working-7.bmp   S5 Cabriolet top not working-8.bmp   S5 Cabriolet top not working-9.bmp   S5 Cabriolet top not working-10.bmp
S5 Cabriolet top not working-11.bmp   S5 Cabriolet top not working-12.bmp   S5 Cabriolet top not working-13.bmp   S5 Cabriolet top not working-14.bmp
Old 03-12-2019, 10:59 PM
cptmrgn's Avatar
Default Update: it’s fixed. Cut cable
Found that the cable had been cut right next to the drivers seat. Spliced it back together and the top is working again!
ortegalco
06-03-2023 12:17 PM
logopolis
09-27-2020 12:05 AM
vineyardmark
B7 Models
04-21-2015 03:45 PM
Arcer
B7 Models
11-28-2011 11:56 PM
Theiceman
09-20-2010 11:09 PM
Quick Reply: S5 Cabriolet top not working
