ONEpointEIGHTtee |
10-11-2011 07:58 AM |
Knocking noise from front end of B6 A4
Ive done a bit of a search already but havent found anything conclusive.
Intermittently over bumps i'll get a sharp "metal-on-metal" sounding knock/clunk noise from the front end. Also hear a similar noise on sharp accel or decel, also intermittently. Usually only hear the noise over a washboard type surface, not big bumps or potholes.
Ive already had the car in the air and done a complete shake down only to find everything is tight as a drum(control arms, tie rods, ball joints, sway bar bushings/endlinks). Also took a dead blow hammer to the tires and different spots on the suspension to see if I could induce the noise...nothing. No clue where this is coming from.
