need help noise comming from front left side
hello plz need help when i drive my car strange noise come from front left side.i lift the car i moved the tire left and right so there was a play and when i do up and down its ok.2day i took the car to the garage the guy said cv boot is tornup it need to be replace and cv joint too but i dont think that its a cv joint cuz if the cv joint is not good condition it should make noise in turning but when i turn my car there is no noise.when i drive the car straight it make tick tick noise when i press half brake it make more noise when i press little hard brake the noise goes away so plz can anyone tell what is it?do i need to change cv joint,tie rod end and ball joint?my car is audi 90 1993 front wheel drive.
RE: need help noise comming from front left side
if its a squeeling noise.. could be wheel bearing
Hi
Thanks for reply i jack up the car then run the engine i saw that the left front side wheel is bumping but the alloys are straight i mean no dent no accdented there is noise like tuck tuck and play do u still think that its a barring?i took to the mechanic but he was talking stupid was saying its ball joint,tie rod end, cv joint and break cant be all when i moved the tire left and right there was the play middle of tie rod assambly but i am not sure what is it.and dont know where that nois comming from but i am sure comming from front left disk so plz give me sum idea what should i check what it could be. Thanks |
hello need help dont know from where the noise comming from plz help me.
Thanks |
did you check the transmission mount brackets or motor mount brackets?
jack the car up grap the tire top n bottom and see if u can move the wheel is be the bearing
ORIGINAL: A4 the Quattro if its a squeeling noise.. could be wheel bearing |
Hi.
I have avibration when I turn left around a left-hand bend. Sometimes I hear a noise, like a rub. It only does it when turning left. It will NOT do it when turning sharp. Also, if I jerk my steering wheel left and right, I hear a glunk under the car. C4 A6Q 2.8 any ideas??> as for your noise, I doubt it is the CV joint b/c it would most likely make noise while turning. Wheel bearings sometimes shut up when braking under load, so light braking would make them noisier. |
intrique420, i would agree with the wheel bearing being the probable cause
