Neuspeed lower springs for A3
I recently had Nuespeed Sport springs installed on my Audi A3. They look great and the car was lowered about 1.5 inches in the front and 2.0 inches in the back. This may sound wierd but the stock A3 is a bit butt high. Now it looks even from front to rear. The only complaint I have is that when I called Neuspeed, they said that I shouldn't need anything else. That the stock shocks should be fine. But that isn't true. The lowering springs lower the car beyond the stock springs range and the car floats too much. This is what I expected would happen but I thought I'd give it a try.
Note to anyone thinking about installing Neuspeed sport springs on their A3, replace the shocks too. Both Bilstein and Koni make shocks that interface with the Neuspeed springs. I'm going with Bilstein and I'll post the results when I do. |
RE: Neuspeed lower springs for A3
Neuspeed's stated "1.2F / 1.5R" threw me quite a bit too. Re: butt-high and levelling the vehicle, I have not noticed that on my Sport Package A3, but in any case wouldn't "1.2F / 1.5R" make the difference in wheel well gap between the front and rear INCREASE? Look forward to seeing your A3 this Sunday.
But not like we have many other choices: 1. Coilovers are 2x as expensive and a pain to get all four struts set at the EXACT same height. 2. Eibach does not currently have the correct Pro-Kit application for the A3, front springs do not fit exactly right. 3. H&R Sports handle great but break your back. |
I have just confirmed with the parts dept. that the shock absorber / damper for the A3 Base, A3 Premium and A3 Sport all have different part numbers. From that, I am inferring that they are different parts. I am further projecting that the Sport Package shocks should be the firmest among the three. So MAYBE I wouldn't need to get new shocks if I get the Neuspeed Sport Springs. Shocks are much 2.5x as expensive as springs. But if I don't get shocks and end up needing them, then it's 2x the labor for installation. Sigh... so much to think about.
