Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Audi A8 Air Ride
Old 04-08-2018, 12:01 PM
Blitz253's Avatar
Exclamation Audi A8 Air Ride
Hey Guys!
I'm new to this forum and have been searching all over for some answers to the problem I am having while working on an 2005 Audi A8 V8.
Issues: air ride compressor is not turning on. Warning lights are on with default "standard and automatic" options. Right front is completely lowered.
Prior to me working on this, a shop diagnosed this car to having a bad air compressor and right front level sensors.
I ordered the parts and installed them with no change. I have also replaced the blown air ride fuse and relay under the dash to rule those out.
I did get a Vag Com cord and tried pulling more codes, I only have Vag Com Lite software but it will not pull codes for the air ride.
Am I missing something? I could really use all inputs and suggestions.
Thank you!!
Old 04-09-2018, 10:50 PM
Blitz253's Avatar
I just put direct power to the new pump and works as it should. Hopefully there is an Audi genius out there that can off some good advise!
richie71
06-07-2017 02:13 AM
Kozzimo55
07-26-2010 08:41 AM
Kozzimo55
B7 Models
07-25-2010 01:17 PM
Kozzimo55
07-24-2010 11:59 PM
Quick Reply: Audi A8 Air Ride
