will/do i need a camber kit?
Lifted up my car to day and the front tires are are shot" warn on the insides" . Will i need a camber kit to fix this problem ? or can the alignment shop adjust the alignment with out a camber kit
Car is a 2002 A4 1.8T AWD Koni Sport Shock /Eibach Pro-Kit Spring Set " 1.4"F 1.3"R " thank you adam |
RE: will/do i need a camber kit?
You will most likely need a chamber kit and new tires ever 10,000 miles if you dont.
good luck |
