16514 - Sensor B1 S1 P0130 - 35-10 - Malfunction in Circ
Car: 2000 Audi TT Quattro 1.8, 180, ATC Engine
I have had issues for several months now. The car no longer boosts. Its like in limp mode. I have had numerous smoke leak tests, compression test and no leaks are ever found. I have new MAF, new diverter, new n75, new PCV..you name it I changed it. I bought the car in March 2017. It ran great after I change the turbo, diverter, n75 and borg warner turbo. I did have a vac leak once..but once that was fixed it ran excellent for a while. Then it didn't...it stopped boosting. I took it to Audi...they said it was the MAF and O2. Ok, so first I changed the MAF with an after market one...and it struggled. It felt like something was clogged.. It stuttered at boost..but still did boost. I thought it might be a faulty MAF, so I then replaced it with genuine Audi. Then I got absolutely no boost. So, I figured..ok, i'll go ahead and change the o2s. I changed them with Bosch O2s. Well, the car took off like a bat at of hell..it ran EXCELLENT and boost for like 30 miles and then it didn't. I purchased VCDS and had P0130 code for S1B1. I then figured, maybe, just maybe I purchased a faulty O2 or the ECU was finiky and I changed it again with a genuine Audi I purchased at the dealer (I also changed the Boost pressure sensor). Still no boost. I am not quite sure what I need to test exactly. First off here is the Autoscan I did after I commuted home today. Monday,23,April,2018,17:54:12:41079 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4 Data version: 20180212 DS287.0 Ross-Tech: Home Mileage: 257260km-159853mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8N - Audi TT (1999 > 2007) Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77 Mileage: 257260km-159853miles ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No: 8N0 906 018 S Component: 1.8L R4/5VT G01 0004 Coding: 06600 Shop #: WSC 01236 VCID: 41DFBB89D893CD7F3D6-513C 1 Fault Found: 16514 - Oxygen (Lambda) Sensor B1 S1 P0130 - 35-10 - Malfunction in Circuit - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8N0-907-379-MK20.lbl Part No: 8N0 907 379 C Component: ABS/EDS 20 IE CAN V003 Coding: 13504 Shop #: WSC 01236 VCID: 3C21CA7DBF71A0976E0-4B00 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8N0-820-043.lbl Part No: 8N0 820 043 Component: TT-KLIMAVOLLAUTOMAT D02 Coding: 00140 Shop #: WSC 01236 VCID: 678B45119677D34FD32-2580 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8N8-909-601.lbl Part No: 8N8 909 601 Component: Airbag Front+Seite 1005 Coding: 10102 Shop #: WSC 01236 VCID: 77AB1551C6D743CF432-5160 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl Part No: 8N1 920 930 C Component: KOMBI+WEGFAHRS. M73 D24 Coding: 06244 Shop #: WSC 131071 VCID: 313FEB4968335DFFCD6-4B00 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 02D-900-554.lbl Part No: 02D 900 554 B Component: HALDEX LSC ECC 0006 VCID: 1F1B1DF10EA7DB8F6B2-4B00 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels:. 8Nx-962-267.lbl Part No: 8N8 962 267 A Component: Central Lock/Alarm D04 Coding: 15884 Shop #: WSC 01236 VCID: 3FDBBD71AE67BB8F4B2-4EEA 3 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01559 - Drivers Door 59-10 - Can't Unlock - Intermittent 01560 - Passenger Door 59-10 - Can't Unlock - Intermittent ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8N8 951 177 A Component: Innenraumueberw. D09 Coding: 00001 Shop #: WSC 00000 VCID: 3D27C779A46BA99F59E-50D0 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl Part No: 4B0 907 357 Component: LEUCHTWEITEREGLER D003 Coding: 00010 Shop #: WSC 01236 VCID: 65974F196C7BC15FE1E-5160 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8D0-035-1xx-56.lbl Part No: 8N0 035 186 A Component: Radio D03 Coding: 00517 Shop #: WSC 01236 VCID: 2E05F035790D4207D04-4B1E No fault code found. End----------(Elapsed Time: 02:15, VBatt start/end: 13.6V/13.6V)----------- I also logged block 115 032 and 033 on my morning drive when the P0130 had not yet showed up. But I don't even know what I am looking at. I can post that too if needed. Any help on what to look for on the P0130 since the pre-cat O2 was changed barely a week ago. Is there a fuse or relay I can possible try? |
Here is the log from the morning of 4.23.18 This is for block 032, 033 and 115. When I started this log, the P0130 was not showing yet.
I will do another on my morning drive to work and post the file here. If there is any other block I should be testing, please let me know and I will post it. |
