VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
A3 8P alarm wont activate
Old 05-20-2018, 09:24 PM
killphil's Avatar
Default A3 8P alarm wont activate
Hi, MY2008 8P 58plate so 2009 model; still has CCM , I have no alarm led showing on dash when locked, also when drivers door open ,the 2 buttons that
turn the Tilt and Interior motion are both on together and wont go out.
also the flashers or horn will not flash or sound when doors are opened or closed. iv tried turning them off and on again with my vag-com .
In measuring blocks it dosent see alarm no communication.
I HAVE made alarm sound by disconnecting and reconnecting the door lock loom, so i know the siren works. If someone thinks they can give me some knowledgeable help or has had the same symptoms in the past . I would be very grateful of their help. and i have put up a full Vag-com read out.
Big thanks in advance: Phil
P.S. have since turned alarm on to PASSIVE , and it will sound if door is opened . but no other funtion..
Monday,21,May,2018,13:18:06:46862
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 56 62 72 77
VIN: WAUZZZ8PX9A035720 Mileage: 191580km/119042miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BS HW: 03L 906 022 BQ
Component: R4 2.0l TDI G000SG 9978
Revision: 13H01--- Serial number: AUX7Z0H7FNI0EJ
Coding: 0000172
Shop #: WSC 61009 001 1048576
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 16426012492500FF681206E6921900823800
Shop #: WSC 18800 000 1048576
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000352 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
6 Faults Found:
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 190856 km
Time Indication: 0
Date: 2018.03.21
Time: 17:46:23
Freeze Frame:
01334 - Door Control Module; Rear Right (J398)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 191556 km
Time Indication: 0
Date: 2018.05.14
Time: 13:56:37
Freeze Frame:
ON
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 191556 km
Time Indication: 0
Date: 2018.05.14
Time: 13:56:37
Freeze Frame:
ON
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
01301 - Control Module for Voice Recognition (J507)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008818293
Coding: 1528AF81B0141380EF00001C0000000000084E056401040300 2800000000
Shop #: WSC 06314 000 08192
Part No: 8P2 955 119 F
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36861229201217
Coding: 000003
Shop #: WSC 19480 000 1048576
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030374A55305238503053
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_Airba10AURB4 001001
ROD: N/A
No ASAM data for: "EV_Airba10AURB4" (AU35)
5 Faults Found:
9440027 - ROD - Unknown Error Code
9439771 - ROD - Unknown Error Code
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 191386 km
Date: 2018.05.03
Time: 00:55:04
9445376 - ROD - Unknown Error Code
0000 - Control Module for Natural Gas Operation (J695)
P0000 00 [000] - -
P0000 00 [000] - -
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2247H006005453
Coding: 0005408
Shop #: WSC 55804 001 10485
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0882103E0
Coding: E9A27F064006022103
Shop #: WSC 19021 000 10485
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 34
Mileage: 191589 km
Time Indication: 0
Date: 2018.05.20
Time: 13:19:13
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H18006 Serial number: AUX7Z0H7FNI0EJ
Shop #: WSC 55804 001 1048576
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
Component: RNS-E HIGH EU H77 0650
Revision: 04S Serial number: AUZBZ7H4115954
Coding: 0209757
Shop #: WSC 00067 210 75633
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 34
Mileage: 191589 km
Time Indication: 0
Date: 2018.05.20
Time: 13:20:23
Freeze Frame:
Mileage: 191580 km
Count: 2005
Clock: 13:20
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000764
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Time Indication: 0
Freeze Frame:
Voltage: 11.50 V
DD
Temperature: 18.0∞C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1880200002D82D280505481FC637
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
Address 52: Door Elect, Pass. Labels: Redir Fail!
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000764
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209757
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 34
Mileage: 191589 km
Time Indication: 0
Date: 2018.05.20
Time: 13:20:23
Freeze Frame:
Mileage: 191580 km
Count: 2005
Clock: 13:20
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000216
Shop #: WSC 06314 000 1012544
1 Fault Found:
00098 - Left Rear Central Locking (Safe) Motor (V163)
012 - Electrical Fault in Circuit - Intermittent
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Component: Tuer-SG H04 0050
Coding: 0000216
Shop #: WSC 06314 000 1012557
2 Faults Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
008 - Implausible Signal - Intermittent
00108 - Signal Central Locking SAVE/LOCK Rear Right
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
Address 46:8P0 959 433 J recoded (Long Coding) from 1880200002D82D280505481FC637 to 1880200002D92D280505481FC637 Monday,21,May,2018,13:40:44:46862
VCDS Version: Beta 912.0
Data version: 20091201
13:40:32
14.0 Alarm Trigger Counter
Piper010
09-20-2010 03:55 PM
TPE_A3
01-08-2008 01:59 AM
DavidM
12-19-2006 02:31 AM
gilee_8
11-10-2005 04:45 PM
star
10-01-2005 05:47 PM
Quick Reply: A3 8P alarm wont activate
