Audi A4 b7 2.0l tdi 170 help with vag codes
Just pulled these faults up as I'm having problems with glow plug light intermittently flashing and when I turn the engine off it seems to shudder to a stop. Also intermittently bad idling and strong smelly exhaust but no smoking. Car runs well otherwise. Thanks in advance for any help.
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8EX8A057116 Mileage: 171590km-106621miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-018-BRD.clb Part No SW: 03G 906 018 AQ HW: 03G 906 018 AQ Component: R4 2.0l PPD1.3 9971 Revision: --H43--- Serial number: XXXXXXXXXXXXXX Coding: 0000072 Shop #: WSC 00045 210 83908 VCID: 74E1AA8B1739FD817B3-8021 2 Faults Found: 012546 - Motor for Intake Manifold Flap (V157) P3102 - 006 - No Signal - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 5 Fault Frequency: 16 Reset counter: 38 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 864 /min Torque: 48.0 Nm Speed: 0.0 km/h 0.00 % Voltage: 12.43 V Torque: 1016.0 Nm Torque: 0.0 Nm 005214 - Mass Air Flow during Regeneration too Low P145E - 006 - - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 5 Fault Frequency: 3 Reset counter: 37 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 1760 /min Torque: 64.0 Nm Speed: 58.0 km/h 0.00 % 85.41 % Mass Air / Rev.: 430.6 mg/str Mass Air / Rev.: 599.5 mg/str Readiness: N/A ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BL Component: A4 Klimaautomat 3233 Coding: 00000 Shop #: WSC 00000 VCID: 6CD1B2EB1C092541A33-5072 2 Faults Found: 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-10 - Open or Short to Plus - Intermittent 00716 - Air recirculation Flap Positioning Motor (V113) 41-00 - Blocked or No Voltage |
