Go Back  AudiForums.com > Audi Tech > VAG-COM
CA Northbay - Petaluma. Would anyone help mobile rosstech/vagcom? >
VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Old 01-05-2016, 01:00 PM
Exclamation CA Northbay - Petaluma. Would anyone help mobile rosstech/vagcom?
Hello All!
I am brand new to this forum, this is regarding my GFs car, 2004 A4 1.8t FWD
I briefly owned an A4 in 2005 but otherwise generally a DIY guy on Jeeps / Chevys
Vehicle will not start after being parked, starter works and tries to turn over
Gas pressure is good, plugs looked bad and two tube seals had failed, replaced them and cleaned ignition coils, air filter alright, no codes, battery holds charge
Aware this could be Cam/MAF/Coolent Sensor/ECU and others
Should I do a compression check?
Recently replaced CCV valve and check valves, car was running fine again. Previous to that it had an intermittent EPC code which was not recorded, and disappeared either prior to or due to CCV valve replacment
Hoping this is not timing, curious about how to check ignition coils and whether they might be covered on an Audi recall for this year/make
Big question is, does anyone have and might be willing to mobilize the rosstech/audi specific reader to the vehicle?
It's located near the Caufield overpass in Petaluma, just don't really want to tow it into a shop just yet as that means 1hr min diagnostics +++
We could compensate some, trying to handle internally because this car has been a hole in the pocket already
Cheers Y'all!
CAR WARS!!!!
AEinaD3
Misc Items for Sale
06-02-2011 06:01 PM
Pro Tools Geek
12-19-2010 01:30 PM
haohuarui414
Wheels/Brakes/Suspension
11-19-2010 12:42 AM
Eric_C
07-13-2009 07:06 PM
smtcapecod
03-26-2007 06:09 PM
Quick Reply: CA Northbay - Petaluma. Would anyone help mobile rosstech/vagcom?
Advertising
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
