Enable Comfort Turn Signals On A Audi A4 B8 3.2 Quattro
Hi, being a noob at vcds I have managed somehow to disable the Comfort Turn signals on my vehicle.
I have added quite a few of the mods listed out there and in the process somewhere along the line managed to disable the function where you simply tap the indicator to indicate lane change. (To which is flashes a few times and auto disables) Yes I know i should have tracked changes. (which i now do) But i have no idea how to enable this again. Anyone out there know the coding to enable this awesome feature again? |
VAG Scan
Wednesday,16,May,2018,18:18:54:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.1.3.0 (x64) Data version: 20170203 DS267.2 Ross-Tech: Home VIN: WAUZZZ8K3AA108936 License Plate: Chassis Type: 8K (8T0) Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77 VIN: WAUZZZ8K3AA108936 Mileage: 150040km-93230miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CALA) Labels: 06E-907-559-CAL.clb Part No SW: 8K0 907 559 HW: 8F0 907 559 B Component: 3.2 SIMOS8.2 H06 0001 Revision: -------- Coding: 0104000C190F0121 Shop #: WSC 06325 123 12345 ASAM Dataset: EV_ECM32FIS8K0907559 A01003 ROD: N/A VCID: 76E43D9AC95C7DF1C3-8022 No ASAM data for: "EV_ECM32FIS8K0907559" (AU48) No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb Part No SW: 8K0 927 158 G HW: 0B6 927 156 Component: 0B6 32 FSIRdW H05 0006 Revision: --H05--- Coding: 001011 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_TCMAL651 A01006 ROD: EV_TCMAL651.rod VCID: 3A7CE9AABDC4D991E7-806E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AL HW: 8K0 907 379 AL Component: ESP8 quattro H04 0080 Revision: -------- Serial number: -------------- Coding: 0F0500 Shop #: WSC 06325 000 00000 VCID: 0302544E828E5859F4-8056 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0327 Revision: 00002001 Coding: 011100 Shop #: WSC 06325 000 00000 VCID: 010E5E4698924A49E6-8054 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Serial number: 0509000073906014 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 0209000100227010 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF Component: KLIMA 3 ZONEN H08 0171 Revision: D0000000 Serial number: 01121220091083 Coding: 46040000 Shop #: WSC 06325 000 00000 VCID: 76E43D9AC15C7DF1C3-8022 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 N HW: 8K0 907 063 N Component: BCM1 1.0 H25 0380 Revision: 09025001 Serial number: 00000000537275 Coding: 2600D8914134AF010001000000001D0D4F1D43080001014100 0000 Shop #: WSC 06325 000 00000 VCID: 3A7CE9AAB5C4D991E7-806E Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB Component: WWS 081008 H05 0070 Serial number: SWF08100080199 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10714775 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090 Serial number: 00000000000712090246 1 Fault Found: 00979 - Lamp for Low Beam; Right (M31) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 23 Mileage: 149183 km Time Indication: 0 Date: 2018.05.12 Time: 12:31:00 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 J HW: 8K0 919 475 A Component: PARKHILFE 8K H06 0050 Revision: 11001001 Serial number: 39840934907703 Coding: 100103 Shop #: WSC 06325 000 00000 VCID: 40889B42D3188341A9-8014 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 G HW: 8K0 959 655 G Component: AirbagVW-AU10 H39 0560 Serial number: 003EFD08BS28 Coding: 30363435363030303030554A3052384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWADUI010 003010 ROD: N/A VCID: 418E9E46D0128A49A6-8014 Subsystem 1 - Serial number: 6334MSME4F054D66Q Subsystem 2 - Serial number: 6344MSME4D430B01A Subsystem 3 - Serial number: 6352QSME3048320A7 Subsystem 4 - Serial number: 6362QSME3E482228L Subsystem 5 - Serial number: 63732SME09471C380 Subsystem 6 - Serial number: 63832SME09471A06. No ASAM data for: "EV_AirbaECUVWADUI010" (AU48) No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90304ILC0009B Coding: 000036 Shop #: WSC 06325 000 00000 VCID: 3D76E2B6A4EAEEA9C2-8068 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 930 B HW: 8K0 920 930 B Component: KOMBIINSTR. H20 0255 Revision: 00100000 Serial number: CIV322CD9 Coding: 2F1F09000200000C010000 Shop #: WSC 06325 000 00000 VCID: 2C50DFF24F90772165-8078 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 R HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0105 Revision: GB600050 Serial number: 5000G09C058437 Coding: 00C303 Shop #: WSC 06325 000 00000 VCID: 50A8AB02037873C139-8004 Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H07 0170 Serial number: 1909FAD9021209 1 Fault Found: 03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 7 Mileage: 148142 km Time Indication: 0 Date: 2018.04.26 Time: 15:59:52 Freeze Frame: Bin. Bits: 10111 Voltage: 11.60 V Count: 6 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 H HW: 8K0 959 793 D Component: TSG FA H11 0306 Revision: Serial number: 0000009804504 Coding: 011C02204001410001 Shop #: WSC 06325 000 00000 VCID: 45868A56CC3AA6699A-8010 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0327 Revision: 00002001 Serial number: 0124991485 Coding: 011A0622003904040130013280000000 Shop #: WSC 06325 000 00000 VCID: 010E5E4698924A49E6-8054 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591 Component: J245 PS037 H06 0041 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-BOC.clb Part No SW: 8T0 035 223 AR HW: 8T0 035 223 AJ Component: DSP Prem H19 0320 Revision: 00019001 Serial number: 34835000372302 Coding: 0203010302 Shop #: WSC 01621 996 999999 VCID: 7EF425BAE96C35B19B-802A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 H HW: 8K0 959 792 D Component: TSG BF H11 0306 Revision: Serial number: 0000009771592 Coding: 011C02204001410001 Shop #: WSC 06325 000 00000 VCID: 44809752C7009F618D-8010 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 10000000396369 Shop #: WSC 00000 000 00000 VCID: 3460C79297A02FE13D-8060 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000004 Shop #: WSC 06324 000 00000 VCID: 77FA309E065604F9D8-8022 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T2 035 186 P HW: 8T2 035 186 P Component: Concert3 H04 0310 Revision: 00000007 Serial number: AUZ5Z6I1324058 Coding: 0503008201018D00835B070002 Shop #: WSC 06325 000 00000 VCID: 45868A56CC3AA6699A-8010 Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E Component: Display No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HL H10 0306 Revision: Serial number: 0000102519821 Coding: 010C02204001210001 Shop #: WSC 06325 000 00000 VCID: 428C914ADD149151BF-8016 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HR H10 0306 Revision: Serial number: 0000102519824 Coding: 010C02204001210001 Shop #: WSC 06325 000 00000 VCID: 428C914ADD149151BF-8016 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8T0 862 335 D HW: 8T0 862 335 D Component: FSE_256x BT H39 0600 Revision: 00000000 Serial number: 00000005145083 Coding: 0010390 Shop #: WSC 06325 000 00000 VCID: 3B72ECAE7AFEE099FC-806E No fault code found. End-------------------------(Elapsed Time: 03:24)-------------------------- |
I don't think even a 1/4 of the people from this forum can understand that code. And even if they do, I'm sure no one can really help you. With such a problem you should consider going to a repair shop. There are the right people to help you with the issue. When my car started showing lousy coding, I immediately took it to a repair centre. They were using https://autoleap.com's software, so it was easy to find out where the problem was and how to fix it. I hear that nowadays most shops use it. Perhaps you can call some repair shops and ask if they can help you out.
