Gremlin???
I have a 2001 Audi TT which has not run right since a few different repairs. The key was re-coded, as it was lost while repairs were being made(yesterday). Symptoms are:
Car races to high, high rpm on start-up Accelerator pedal seems either disconnected or in limp mode. If you don't make it to the bottom of the vag-com data, I am open to wild guesses, prayers, magic, black magic, and whatever else you might think handy. Most puzzling is the "No redir" at the very top of the ecm DTC listing. Thanks in advance, J Witt VCDS-Lite Version: Release 1.2 Saturday, 14 February 2015, 14:12:33. Control Module Part Number: 8N8 962 267 A Component and/or Version: Central Lock/Alarm D06 Software Coding: 15884 Work Shop Code: WSC 00050 VCID: 3FF1C0FF2E65 9 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01374 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 01370 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 01616 - Shareware Version. To Decode all DTCs 36-10 - Please Register/Activate - Intermittent 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent 01559 - Shareware Version. To Decode all DTCs 58-00 - Please Register/Activate 00849 - Shareware Version. To Decode all DTCs 31-00 - Please Register/Activate VCDS-Lite Version: Release 1.2 Saturday, 14 February 2015, 16:09:23. Chassis Type: 8N - Audi TT Scan: 01,02,03,08,15,17,22,35,37,45,55,56,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Controller: 8N0 906 018 K Component: 1.8L R4/5VT G 0003 Coding: 06710 Shop #: WSC 24338 VCID: 3905AEE73041 TRUWT28N511041187 AUZ5Z0A3020023 6 Faults Found: 18039 - Accelerator Position Sensor (G79): Signal too High P1631 - 35-00 - - 18042 - Shareware Version. To Decode all DTCs P1634 - 35-00 - Please Register/Activate 16727 - Shareware Version. To Decode all DTCs P0343 - 35-00 - Please Register/Activate 17524 - Oxygen (Lambda) Sensor Heating; B1 S1: Open Circuit P1116 - 35-00 - -(I intentionally unplugged it to see if it was my problem) NO CHANGE 16684 - Shareware Version. To Decode all DTCs P0300 - 35-00 - Please Register/Activate 16518 - Shareware Version. To Decode all DTCs P0134 - 35-00 - Please Register/Activate Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: None Controller: 8N0 907 379 E Component: ESP 20 CAN V005 Coding: 18446 Shop #: WSC 06201 VCID: 3E0FBDFB296F 1 Fault Found: 00778 - Steering Angle Sensor (G85) 62-00 - No or Incorrect Adjustment |
Seriously this many people have read it and not one suggestion?
