Help needed with Fault codes
I ran a scan on my 04 Allroad because the check engine light came on and noticed the car is running a bit different this is what I get
I just don't know where to go from here. Please help Address 01: Engine Labels: 078-907-551-AZA.lbl Part No: 4Z7 907 551 R Component: U25AN34.hex LEV G x Coding: 07755 Shop #: WSC 02334 VCID: 52AB590F9E8C81B188B-5140 Subsystem 1 - Part No: XXYOUR Component: VIN HEREXX XXXIMMO IDXXXX XXYOUR VIN HEREXX XXXIMMO IDXXXX 7 Faults Found: 16515 - Oxygen (Lambda) Sensor B1 S1 P0131 - 35-00 - Signal too Low 16534 - Oxygen (Lambda) Sensor B2 S1 P0150 - 35-10 - Malfunction in Circuit - Intermittent 17536 - Fuel Trim; Bank 1 (Mult) P1128 - 35-00 - System too Lean 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - Intermittent 16685 - Cylinder 1 P0301 - 35-10 - Misfire Detected - Intermittent 16687 - Cylinder 3 P0303 - 35-10 - Misfire Detected - Intermittent 16686 - Cylinder 2 P0302 - 35-10 - Misfire Detected - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4Z7-907-553.lbl Part No: 4Z7 907 553 F Component: - 2C1A1 D060 Coding: 25500 Shop #: WSC 02334 VCID: 489F7B6768D03B61E6F-5140 1 Fault Found: 01400 - Suspension Level Control 11-10 - Control Limit Not Reached - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 4B0-962-258.lbl Part No: 4B0 962 258 M Component: Central Lock/Alarm D38 Coding: 15885 Shop #: WSC 02334 VCID: 33653C8B0156A8B9A3D-4F06 4 Faults Found: 01374 - Alarm triggered by Terminal 15 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01562 - Rear right door 59-10 - Can't Unlock - Intermittent 01574 - Alarm triggered by Door Contact Switch; Rear Right 35-00 - - |
