VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
HELP WITH VAGCOM PLEASE
Old Sep 1, 2007 | 07:10 AM
paulrob2808's Avatar
Default RE: HELP WITH VAGCOM PLEASE
On the vagcom site, which download do i need , there are a number of them listed.
Old Sep 1, 2007 | 08:34 AM
onepoint8tee's Avatar
I use 311.2
Old Sep 1, 2007 | 10:30 AM
techbod's Avatar
Old Sep 1, 2007 | 10:49 AM
onepoint what car are you using it on and what year.
Old Sep 1, 2007 | 10:57 AM
Im using it on my car, of course. Its a 00, but that doesnt matter. Vag com will work with any 96+ OBDII Audi/Vw.
Im a little confused about what you are doing to get it to work. If you have the USB adapter drivers installed, go into windows device settings and assign port 3 to your USB adapter. Select com port 3 in vag com and see what happens.
Old Sep 1, 2007 | 11:17 AM
techbod's Avatar
409 and 311 will work on cars prior to 02 because that's when CAN became involved so some 02 cars it works but around 02.5 it all changed,
there are 3 different cables KEY/micro/hex+
KEY is the eBay type,
MICRO is semi pro and backward compatible with the older cars,
HEX is for 02.5 upward and pro series software 709 release and dosnt work with the other connectors,
so it could be his 02 car is the later type and needs HEX 709
Old Sep 1, 2007 | 11:22 AM
ORIGINAL: avant80@2.6
2 things...
1. I understood ALL of what you just said (sorry man, hardly ever happens )
2. I agree with you (hardly ever happens )
Good point.
Old Sep 1, 2007 | 11:24 AM
  #18
techbod's Avatar
well at least we agree to disagree lol
edit: plus im a tech so I understand me, your not a tech but if im going too fast for you ill water it down a little so you catch on easier
Old Sep 1, 2007 | 11:39 AM
  #19
Yes, youmake it clear in almostevery one of your posts thatas long as you understand you, thats all that matters...........to you [&:]
edit: If anything needs watered down a little, its your drink, before you post
Old Sep 1, 2007 | 11:44 AM
  #20
techbod's Avatar
this reply is disappointing and makes me wonder if anyone understands me ( especially from a moderator ) which is disrespectful to say the least so ill now consider if its worth me staying on this site if that's what you think
