new to this help please
VIN: WA1AV94L17D030829 License Plate:
Mileage: 150500km-93516mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4L (4L0) Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 34 36 42 46 47 4F 52 55 56 61 62 65 6D 6F 72 77 VIN: WA1AV94L17D030829 Mileage: 150500km/93516miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: Cannot be reached 1100 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4L0 910 560 C HW: 4L0 907 560 A Component: 4.2l V8/4V 0060 Revision: --H16--- Serial number: Coding: 01210009190F0560 Shop #: WSC 22172 444 66630 VCID: 285F1E2B9B06C05EFC3-807D No fault code found. Readiness: 0000 0100 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09D-927-750.lbl Part No SW: 09D 927 750 FH HW: 09D 927 750 FH Component: AL 750 6A 0959 Revision: 00H52000 Serial number: Coding: 0000504 Shop #: WSC 31414 790 00001 VCID: 79F90B6F302C89D6D3D-802C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4L0-910-517.clb Part No SW: 4L0 910 517 A HW: 4L0 614 517 A Component: ESP ALLRAD MK25E1 0130 Revision: 00H21001 Coding: 0021553 Shop #: WSC 31414 790 00001 VCID: 285F1E2B9B06C05EFC3-807D 1 Fault Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 51 Mileage: 150509 km Time Indication: 0 Date: 2014.02.17 Time: 08:35:38 Freeze Frame: Count: 0 Count: 12289 Count: 128 Count: 40704 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0210 Revision: 27120501 Serial number: 10601000468041 Coding: 0000139 Shop #: WSC 22172 444 66630 VCID: E3C5C90722A0E306691-80B6 Subsystem 1 - Part No: 4F0 910 131 J Component: FBSAUDIC6 EZS H45 0080 Subsystem 2 - Part No: 4F0 910 220 A Component: FBSAUDIC6 IDG H01 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl Part No SW: 4L0 910 729 Q HW: 4E0 035 729 Component: Interfacebox H43 2740 Revision: 00000000 Serial number: 308FJ067504341 Coding: 0002003 Shop #: WSC 31414 790 00001 VCID: 3D71DF7F648475F6BF5-8068 Subsystem 1 - Part No: 4L0 910 609 Component: E0380 BedienteilH01 0050 Subsystem 2 - Serial number: 00000000445869 Subsystem 3 - Serial number: 0119.06.060000000100010497˙ Subsystem 4 - Serial number: 010497˙ 3 Faults Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 91 Mileage: 150509 km Time Indication: 0 Date: 2014.02.16 Time: 19:24:36 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 91 Mileage: 150509 km Time Indication: 0 Date: 2014.02.16 Time: 19:24:36 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 7 Reset counter: 90 Time Indication: 15 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4L0 910 043 HW: 4L0 820 043 E Component: KLIMABETAETIGUNGH05 0060 Revision: 00---008 Serial number: 00000000040631 Coding: 0524328 Shop #: WSC 31414 790 00001 VCID: E1C9C30F38BCF1167BD-80B4 1 Fault Found: 02508 - Temperature Sensor for Refrigerant (G454) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 50 Mileage: 150402 km Time Indication: 0 Date: 2014.02.15 Time: 14:36:43 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 J HW: 4F0 907 279 A Component: ILM Fahrer H17 0240 Revision: 00000000 Serial number: 4F0907279 Coding: 0114123 Shop #: WSC 31414 790 00001 VCID: 306FF64BA3D6889E243-8065 Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AU716 H12 0080 Coding: 00064792 Shop #: WSC 31414 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH12 0090 Coding: 00150059 Shop #: WSC 31414 1 Fault Found: 02745 - Bulb for Daytime Running Light; Left 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 52 Mileage: 150400 km Time Indication: 0 Date: 2014.02.15 Time: 14:36:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4L0 910 111 A HW: 4L0 035 111 Component: CD-Changer H41 0100 Revision: 00000000 Serial number: AUZ5ZBF3027699 Shop #: WSC 00000 000 00000 VCID: 1E3338F3C9420EEE86F-804B No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.lbl Part No SW: 4L0 910 655 A HW: 4L0 959 655 B Component: 72 AIRBAG AUDI8RH39 0210 Revision: 03H39000 Serial number: 0038QD032BS8 Coding: 0014130 Shop #: WSC 31414 790 00001 VCID: 2B55E1278AF0EB46111-807E Subsystem 1 - Part No: 4L0 910 339 Component: BF-Gewichtsens. H02 0020 Subsystem 2 - Serial number: 6332QSME1029265DD Subsystem 3 - Serial number: 6342QSME10384E118 Subsystem 4 - Serial number: 6352QSME1048426FH Subsystem 5 - Serial number: 6362QSME10591E03B Subsystem 6 - Serial number: 63734SME11721509R Subsystem 7 - Serial number: 63834SME11722C1F0 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H08 0230 Revision: 00H08000 Serial number: 90026061750269 Coding: 0012042 Shop #: WSC 31414 790 00001 VCID: E6C3D013D192962E8EF-80B3 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4L0-910-xxx-17.lbl Part No SW: 4F0 910 900 C HW: 4L0 920 950 B Component: KOMBIINSTR. M73 H11 0110 Revision: 00200000 Serial number: 4ZS74R676 Coding: 2673263 Shop #: WSC 22172 067 57207 VCID: 204F060BF336381EB43-8075 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.lbl Part No SW: 4L0 910 468 HW: 4L0 907 468 Component: J533__Gateway H06 0040 Revision: 00H06000 Serial number: 0900B0663080B2 Coding: E5D7BE7F301202 Shop #: WSC 22172 444 66630 VCID: ECD7A23BCF7EAC7ED8B-80B9 2 Faults Found: 00463 - Control Module for Digital Sound Package (J525) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 50 Mileage: 150402 km Time Indication: 0 Date: 2014.02.15 Time: 14:37:41 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 90 Mileage: 150443 km Time Indication: 0 Date: 2014.02.15 Time: 17:31:06 ------------------------------------------------------------------------------- Address 34: Level Control Labels: None VCID: 55A167DFBCF48DB6975-8000 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4L0 959 760 Component: Sitzmemory FS H01 0100 Revision: 00000000 Serial number: 00000000896401 Coding: 0082946 Shop #: WSC 31414 790 00001 VCID: E1C9C30F38BCF1167BD-80B4 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl Part No SW: 4L0 910 793 B HW: 4L0 959 793 B Component: TSG FA H12 0130 Revision: 00000000 Serial number: 9w Coding: 0035531 Shop #: WSC 31414 790 00001 VCID: 2F6DF537BEE897663D9-807A No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Cannot be reached ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 B Component: ILM Beifahrer H10 0080 Revision: Serial number: 00000000030179 Coding: 0012001 Shop #: WSC 31414 790 00001 VCID: DEB3F8F309C2CEEE46F-808B No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl Part No SW: 4L0 910 793 B HW: 4L0 959 792 B Component: TSG BF H12 0130 Revision: 00-00000 Coding: 0035531 Shop #: WSC 31414 790 00001 VCID: 2F6DF537BEE897663D9-807A No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000022 Shop #: WSC 31414 790 00001 VCID: 29591B2F800CF956E3D-807C Subsystem 1 - Part No: 7L6 941 329 A Component: AFS-Modul links H06 0002 Subsystem 2 - Part No: 7L6 941 329 A Component: AFS-Modul rechtsH06 0002 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 M HW: 4E0 035 541 P Component: TUNER EU/US/RDW H42 0570 Revision: 00000000 Serial number: 388F0067537468 Coding: 0000002 Shop #: WSC 31414 790 00001 VCID: 2A5BE423850AF24EEA7-807F No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Cannot be reached ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4L0-910-795.lbl Part No SW: 4L0 910 795 B HW: 4L0 959 795 B Component: TSG HL H21 0050 Coding: 0035338 Shop #: WSC 31414 790 00001 VCID: 3169F34FA8DC81962BD-8064 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl Part No SW: 4F0 910 273 B HW: 4F0 907 273 A Component: Reifendruck 3 H05 0100 Revision: 00050100 Serial number: 00000700024683 Coding: 0062424 Shop #: WSC 31414 790 00001 VCID: 224B0C03FD3A2A0EA27-8077 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: None Part No SW: 4L0 910 945 HW: 4L0 827 851 A Component: ValeoHeckdeckel H20 0280 Revision: --H20001 Serial number: E5030000B Shop #: WSC 98765 666 38354 VCID: ECD7A23BCF7EAC7ED8B-80B9 Subsystem 1 - Part No: 4L0 910 946 Component: ValeoHeckdeckel H20 0280 Subsystem 2 - Serial number: E5030100B Subsystem 3 - Serial number: RD03.07.06--H20001001B0228˙ Subsystem 4 - Serial number: 1B0228˙ No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl Part No SW: 4L0 910 290 A HW: 4L0 907 290 A Component: ILM HINTEN 2 H05 0040 Revision: AAH05044 Serial number: 001747817----- Coding: 0003595 Shop #: WSC 31414 790 00001 VCID: 264310139112D62ECEF-8073 Subsystem 1 - Part No: 4L0 910 591 Component: J_245_EE14_SKB09H10 0160 Subsystem 2 - Part No: 4L0 910 591 Component: J_394_EE14_SKB09H10 0160 Subsystem 3 - Part No: 4L0 910 591 Component: J_392_EE14_SKB09H10 0160 3 Faults Found: 02915 - Sensor 2 for Trunk/Hatch Closed (G526) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 90 Mileage: 150443 km Time Indication: 0 Date: 2014.02.15 Time: 17:23:24 02914 - Sensor 1 for Trunk/Hatch Closed (G525) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 90 Mileage: 150443 km Time Indication: 0 Date: 2014.02.15 Time: 17:23:24 01516 - Terminal 30; Left 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 90 Mileage: 150443 km Time Indication: 0 Date: 2014.02.15 Time: 17:26:50 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4L0-910-795.lbl Part No SW: 4L0 910 795 B HW: 4L0 959 794 B Component: TSG HR H21 0050 Coding: 0035338 Shop #: WSC 31414 790 00001 VCID: 3169F34FA8DC81962BD-8064 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 H HW: 4E0 862 335 Component: Handyvorb2 H20 1130 Revision: 00000000 Serial number: 00000005077760 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 285F1E2B9B06C05EFC3-807D 1 Fault Found: 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 50 Mileage: 150402 km Time Indication: 0 Date: 2014.02.15 Time: 14:36:44 End --------------------------------------------------------------------- |
I had a recent flood from the drain tubes so trying to get a different amp to work will updating the software help
Thanks guys
