No windows Vag Com scan
Long story short. Had my turbo timer installed. After that ALL and ONLY the windows stopped working. I have a 2000 Audi A4 1.8t Quattro 5 speed and it's getting warm out so opening the windows would really help. My friend said he tapped into the central locking but if I use my key in the driver's side door I can bring all the windows down and up. Can you guys tell me what might be the problem with this? The central locking codes were clear to see which one would come up again seeing how last month someone tried to break into my baby & broke the locking mechanism on my driver's door. Thanks in advance.
VCDS Version: Release 12.12.0 Data version: 20130910 Wednesday,12,February,2014,17:14:26:26926 Chassis Type: 8D - Audi A4 B5 (1995 > 2001) Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 058-906-018-ATW.lbl Part No: 4B0 906 018 P Component: 1.8L R4/5VT G 0006 Coding: 07201 Shop #: WSC 08126 VCID: 2E58B81CEA7E6B6E36F-5120 No fault code found. *These were cleared* Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl Part No: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D10 Shop #: BB 24334 VCID: 1C3C62D48CC2E9FE68B-5120 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl Part No: 8D0 820 043 P Component: A4 KLIMAAUTOMAT D56 Coding: 00140 Shop #: WSC 06335 VCID: 2D5ABF10E77810760F5-2578 2 Faults Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-00 - Blocked or No Voltage 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI8.lbl Part No: 8D0 959 655 K Component: Airbag Front+Seite 0002 Coding: 00104 Shop #: WSC 06335 VCID: 3E78885C3A1E9BEEA6F-515A No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-920-xxx-17.lbl Part No: 8D0 920 980 CX Component: B5-KOMBIINSTR. VDO D17 Coding: 02244 Shop #: WSC 08167 VCID: 830EB9A8917CB606091-5120 2 Faults Found: 00771 - Fuel Level Sensor (G) 30-10 - Open or Short to Plus - Intermittent 00849 - S-contact at Ignition/Starter Switch (D) 31-10 - Open or Short to Ground - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8L0 862 257 N Component: CV-Pump D11 Coding: 15215 Shop #: WSC 06335 VCID: 4084F6A440EAED1ED43-4ECA No fault code found. *These were cleared* ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00101 Shop #: WSC 06335 VCID: E0C49624602A0D1E743-4B00 1 Fault Found: 01381 - Alarm triggered by Anti-Theft Sensor; Rear Right 35-00 - - ------------------------------------------------------------------------------- Address 56: Radio Labels: 8D0-035-1xx-56.lbl Part No: 8D0 035 195 A Component: Radio D00 Coding: 00207 Shop #: WSC 06335 VCID: 244C5A34B4B2D13ED0B-4AE6 No fault code found. End --------------------------------------------------------------------- |
No one can help me?
