PRNDS lights flashing
hi guys,
I have an Audi A4 2.0 FSI SE 4dr Multitronic Saloon 2004 with 44,000 miles. PRNDS lights started flashing the other day and its shifting between D and S, but I didn't loose any power. Diagnostics says: 18201- transmission speed sensor 2 (G196) No Signal P1793 17090 - transmission range sensor (F125) Implausible Signal P0706 Intermittent. i am bit confused as to what needs to be changed? do I have to change few sensors or whether transmission ECU needs to be replaced? Are sensors located outside the gear box? What kind of cost are we looking at? I booked an appointment with an Audi dealer but they charge like £135+vat / hour. Ouch!!!! I found a company in uk that can rebuild ecu for like £250. But I don't know what the problem is and whether rebuilt ecu will work fine as its located, I believe, inside gearbox and its replacement is probably 4-5 hour job. Any help will be appreciated. Thanks. |
I may be wrong here. I'm not sure about Multitronic boxes, but if it were a DSG, it sounds like the mechatronics unit is malfunctioning. if you're lucky it's just the control module that can be replaced or flashed. If not that, you need a new mechatronics unit. If it comes to replacing it altogether, then i'd suggest you look for a used part. They tend to be quite steep in pricing.
I'll research on the codes and get back to you though. Keep us updated. :) |
