South Jersey VagCom help needed will pay..
Looking for someone to come to my place and plug into the car to do a Throttle body adjustment and clear codes.
99.5 with K04 and GIAC pc-16
This is what the cars doing:
P1545
P1613
P1505
I had someone try to clear the codes for me a while ago, but I don't know if he tried to do the throttle body adjustment or not. I also put a stock ECU in and I'm getting the same codes with that one. The shop that looked at it before even tried putting on a new Throttle body but only got the same codes they couldn't clear so I'm sure it has something to do with the ECU.
I'm willing to pay you for your time if it fixes it or not.
P1545
P1613
P1505
On my 2001 A4 1.8t, I could do the following for a TBA.
Disconnect the battery for 5 minutes. You'll need your radio code.
Reconnect the battery.
Turn the key part way, do not crank the engine. Wait with the dash lit for 2 minutes.
Now crank the engine to start.
This is how the TBA is done on a 2001.
