Vag com Code reading help please
Hi Thank you for reading, A bit about the car its a 2004 audi a3 tiptronic. bought it with a limp mode issue . found this to be clogged turbo veins i have no replaced these and that issue has now gone. however the car is very temperamental ... If i was to drive it from cold it will drive ok, however when the car seems to get warm i will attempt to pull off from a standstill and the car will hesitate dramatically (not the normal automatic) i will move my foot on the accelerate slightly and all of a sudden bam!!! its off like a rocket however this becoming quite dangerous to drive now as i am unsure if to pull out on the roundabout now or not... please help,
These are the codes that i have come up when running VAG,com. the EGR has been deleted so I know thats an error code but the other i don't.. Thank you Tuesday,21,March,2017,09:43:56:06598 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.1.2.0 (x64) Data version: 20170107 DS267.0 Ross-Tech: Home VIN: WAUZZZ8P44A106614 License Plate: AUDI A TURBO Mileage: 201460km-125181mi Repair Order: Chassis Type: 8P (1K0) Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D VIN: WAUZZZ8P44A106614 Mileage: 201460km-125181miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 1010 47-Sound System -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 7D-Aux. Heat -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKD.lbl Part No SW: 03G 906 016 AT HW: 028 101 145 3 Component: R4 2,0L EDC G000AG 5689 Revision: 12345678 Serial number: AUX7Z0C9FNQ019 Coding: 0000078 Shop #: WSC 06435 000 00000 VCID: 75E1EE931CD8F0E9C0-8020 2 Faults Found: 16618 - Boost Pressure Regulation P0234 - 000 - Limit Exceeded (Overboost Condition) Freeze Frame: RPM: 2394 /min Torque: 278.0 Nm Speed: 94.0 km/h Load: 72.9 % Voltage: 14.36 V Bin. Bits: 10101100 Absolute Pres.: 2213.4 mbar Absolute Pres.: 2590.8 mbar 16785 - EGR System P0401 - 000 - Insufficient Flow Freeze Frame: Readiness: 1 1 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.clb Part No SW: 02E 300 041 C HW: 02E 927 770 G Component: GSG DSG 0623 Revision: 02100224 Serial number: 00000310270092 Coding: 0000020 Shop #: WSC 06435 000 00000 VCID: 122BB50F0D7647D145-8046 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No: 1K0 907 379 K Component: ESP FRONT MK60 0103 Coding: 0023174 Shop #: WSC 06435 000 00000 VCID: 3A7B3DAF75465F91ED-806E No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 F HW: 8P0 820 043 F Component: KlimavollautomatH12 0150 Revision: 001354 Serial number: 8P0820043F Shop #: WSC 00000 000 00000 VCID: 2F6D1CFBBE048A394A-807A 1 Fault Found: 00797 - Sunlight Photo Sensor (G107) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 181 Mileage: 150182 km Time Indication: 0 Date: 2013.11.16 Time: 08:10:16 Freeze Frame: ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl Part No SW: 8P0 907 279 A HW: 8P0 907 279 A* Component: Bordnetz-SG 1.0 H29 0501 Revision: 00029000 Serial number: 00000000190054 Coding: 01884F00A2141000000000000000000000 Shop #: WSC 00000 000 00000 VCID: 3B7538AB7A7C6699F6-806E Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB Component: Wischer WWS Audi350 0180 Coding: 16711696 Shop #: WSC 00000 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8P0-959-655-84.lbl Part No SW: 8P0 959 655 F HW: 8P0 959 655 F Component: Airbag 8.4ED H01 0130 Coding: 0011602 Shop #: WSC 06435 000 00000 VCID: 45815E530CB8206990-8010 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8P0-953-549.lbl Part No SW: 8P0 953 549 HW: 8P0 953 549 Component: Lenksäulenmodul H10 0020 Coding: 0011142 Shop #: WSC 06435 000 00000 VCID: 7BF5F8AB3AFCA699B6-802E Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 980 H HW: 8P0 920 980 H Component: KOMBIINSTR. VDO H25 0110 Revision: D07 Serial number: 2249CD07001680 Coding: 0000403 Shop #: WSC 00999 067 57207 VCID: 3C773BB77F7261A1FF-8068 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 B HW: 1K0 907 951 Component: Gateway H08 0090 Revision: 08 Serial number: 240010390642E6 Coding: 3F0F0B42070101 Shop #: WSC 06435 000 00000 VCID: 2643F9DF91FECB71B9-8072 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 216 Time Indication: 0 Date: 2017.03.16 Time: 10:58:22 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8P0 920 980 H HW: 8P0 920 980 H Component: KOMBIINSTR. VDO H25 0110 Revision: D07 Serial number: AUX7Z0C9FNQ019 Shop #: WSC 00000 000 00000 VCID: 3C773BB77F7261A1FF-8068 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl Part No: 8P0 959 801 A Component: Tuersteuerger. H10 0010 Coding: 0000048 Shop #: WSC 06435 000 00000 VCID: 397922A370405489E4-806C 2 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication - Intermittent 00913 - Window Regulator Switch; Front Right Driver (E81) 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K2 909 144 E Component: EPS_ZFLS Kl.10 1202 Shop #: WSC 00000 000 00000 VCID: 2E5301FFB90E833141-807A 1 Fault Found: 02441 - Yellow Malfunction Lamp in Instrument Cluster 013 - Check DTC Memory - Intermittent Freeze Frame: Mileage: 1440 km Temperature: 8.0°C Voltage: 12.00 V Voltage: 11.90 V ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8P0-959-433.lbl Part No: 8P0 959 433 Component: KSG H02 0040 Coding: 008800186D288505485AC63000 Shop #: WSC 06435 000 00000 VCID: 79F9E2A330C09489A4-802C Subsystem 1 - Component: Sounder No Answer Subsystem 2 - Part No: 1K0 907 719 Component: Neigungssensor 002 0002 Subsystem 3 - Part No: 8P0 951 177 Component: Innenraumueberw.H03 0010 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 47: Sound System Labels: 8Px-035-382.lbl Part No SW: 8P3 035 382 HW: 8P3 035 382 Component: AB2 SUBWOOFERBOXH23 0100 Revision: 00001 Serial number: 10000001083065 Shop #: WSC 00000 000 00000 VCID: 70EFDF8763BAD5C113-8024 2 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 199 Mileage: 200738 km Time Indication: 0 Date: 2063.15.31 Time: 31:63:63 Freeze Frame: Temperature: 5.0°C Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 199 Mileage: 200738 km Time Indication: 0 Date: 2063.15.31 Time: 31:63:63 Freeze Frame: Temperature: 5.0°C Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl Part No: 8P0 959 802 A Component: Tuersteuerger. H10 0010 Coding: 0000048 Shop #: WSC 06435 000 00000 VCID: 3A7B3DAF75465F91ED-806E 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 8P0-035-1xx-56.lbl Part No SW: 8P0 035 195 HW: 8P0 035 195 Component: symphony II EU H55 0400 Revision: 19S Serial number: AUZ5Z4C5339060 Coding: 0001001 Shop #: WSC 00539 210 08758 VCID: 6FEDDCFB7E84CA390A-803A No fault code found. ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 C HW: 1K0 963 235 C Component: PTC-Element 0404 Revision: 00600000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2B5508EB8A1CF61966-807E No fault code found. End-------------------------(Elapsed Time: 01:50)-------------------------- |
