Vag- Com errors
I have been observing this vehicle for the past couple of days. Yesterday I drove the car to work let it sit for twelve hours (checking it periodically) and there was no movement. Went to movies and dinner, arriving back home around eleven and still no problem. This morning around five the left rear tire was down, pretty much under the wheel well, I could not get the car to lift so I guess it lowered the passenger rear to compansate. After arriving at work both rear tires where down, and the minute I shut the car off and shut the door both rear tires are raised.
The past two days there has not been any movement form my suspension, I still get the yellow suspension light sometimes, but it does go away. Wednesday,17,July,2013,15:14:15:04768 VCDS Version: Release 11.11.6 (x64) Data version: 20121223 Address 34: Level Control Labels: 4E0-910-553.lbl Control Module Part Number: 4E0 910 553 H HW: 4E0 907 553 F Component and/or Version: LUFTFDR.-CDC H06 4480 Software Coding: 0015510 Work Shop Code: WSC 02313 785 00200 VCID: 285F13559BE1BB5848B 5 Faults Found: 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 205 Reset counter: 33 Mileage: 186198 km Time Indication: 0 Date: 2013.05.07 Time: 12:32:29 01577 - Turn-Off due to Over-Temp 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 4 Fault Frequency: 23 Reset counter: 31 Mileage: 186232 km Time Indication: 0 Date: 2013.05.07 Time: 16:53:17 01400 - Suspension Level Control 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 23 Reset counter: 34 Mileage: 188395 km Time Indication: 0 Date: 2013.06.06 Time: 17:26:30 01583 - Leak in System Detected 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 33 Reset counter: 34 Mileage: 188922 km Time Indication: 0 Date: 2013.06.15 Time: 06:50:43 01770 - Temperature Sensor for Level Control Pump/Compressor (G290) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 1 Mileage: 190565 km Time Indication: 0 Date: 2013.06.30 Time: 15:29:50 Wednesday,17,July,2013,15:19:23:04768 VCDS Version: Release 11.11.6 (x64) Data version: 20121223 Address 56: Radio Labels: 4E0-910-541.lbl Control Module Part Number: 4E0 910 541 F HW: 4E0 035 541 E Component and/or Version: TUNER EU/US/RDW H42 0480 Software Coding: 0000002 Work Shop Code: WSC 02313 785 00200 VCID: 23450479E2C758001D9 1 Fault Found: 00856 - Radio Antenna 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 |
