VAG-COM Fault Codes HELP !
Hello !
So i managed to do a scan of my facelift 1999 Audi A8 2,5 TDI V6 I have some modules where it seems that there are some faults and i would like to have some explanations , if you guy's have some ideeas of what i can do ! here are the faults : VAG-COM Version: Release 409.1-S Chassis Type: 4D - Audi A8 D2 Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,65,76 Address 03: ABS Brakes Controller: 4D0 907 389 B Component: ABS/ESP front D05 Coding: 00000 Shop #: WSC 00000 2 Faults Found: 01044 - Control Module Incorrectly Coded 35-00 - - 18036 - Powertrain Data Bus: Missing Message from Steering Angle Sensor P1628 - 35-00 - - Address 56: Radio Controller: 4B0 035 192 KX Component: Radio BNO 0001 Coding: 00205 Shop #: WSC 00000 1 Fault Found: 01044 - Control Module Incorrectly Coded 35-00 - - Could Anybody give me some ideas what to change and what to check ?! Best, Johnny ! |
anyone !?
Hellooooooooo ?! :)
p1628--CAN Data Bus, Steering Position Sensor - No Signal,Is an automotive communication protocol, which is characterized by allowing devices on the network communicate directly with each other on the network for host communication.
