VAG-COM Fault Codes HELP !
Hello !
So i managed to do a scan of my facelift 1999 Audi A8 2,5 TDI V6
I have some modules where it seems that there are some faults and i would like to have some explanations , if you guy's have some ideeas of what i can do !
here are the faults :
VAG-COM Version: Release 409.1-S
Chassis Type: 4D - Audi A8 D2
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,65,76
Address 03: ABS Brakes
Controller: 4D0 907 389 B
Component: ABS/ESP front D05
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
18036 - Powertrain Data Bus: Missing Message from Steering Angle Sensor
P1628 - 35-00 - -
Address 56: Radio
Controller: 4B0 035 192 KX
Component: Radio BNO 0001
Coding: 00205
Shop #: WSC 00000
1 Fault Found:
35-00 - -
Could Anybody give me some ideas what to change and what to check ?!
Best,
Johnny !
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
35-00 - -
P1628 - 35-00 - -
Address 56: Radio
Coding: 00205
Shop #: WSC 00000
1 Fault Found:
35-00 - -
Best,
Johnny !
p1628--CAN Data Bus, Steering Position Sensor - No Signal,Is an automotive communication protocol, which is characterized by allowing devices on the network communicate directly with each other on the network for host communication.
