VAG COM Scan - Please Help
Team I need help. I just ran a VAG COM scan on my Audi Q7 and this is what I get as the scan results. What's surprising is that there are many modules which show as "cannot be reached" but are functional. E.g. Park Assist, Backup Camera etc.
Also to let you know the only 2 problems that are visible on the Q7 us that the Side Assist Does not work and gives a message "Audi Side Assist System Fault" and Bluetooth gives a message "Phone not installed" I assume there is some wiring which is loose but don't know where to start looking. Any help would be appreciated. __________________________________________________ ___________ Sunday,24,November,2013,21:36:31:32264 VCDS Version: Release 11.11.3 Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4L0 Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 28 36 37 3C 42 46 47 4F 52 55 56 5C 61 62 65 67 69 6C 6D 6F 72 76 77 VIN: WA1BV74L18D030792 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Malfunction 0010 0F-Digital Radio -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: OK 0000 3C-Lane Change -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: Sporadic communication error 1000 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5C-Lane Maintain. -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4L0 910 560 G HW: 4L0 907 560 B Component: 4.2l V8/4V 0020 Revision: 78H02--- Serial number: Coding: 01210009190F0960 Shop #: WSC 31414 790 00001 VCID: 2C5D1A698F10169 2 Faults Found: 000136 - Fuel Rail/System Pressure P0088 - 001 - Too High - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Mileage: 143873 km Time Indication: 0 Date: 2013.11.24 Time: 12:57:20 Freeze Frame: RPM: 910 /min Load: 37.6 % Speed: 7.0 km/h Temperature: 88.0°C Temperature: 39.0°C Absolute Pres.: 1020.0 mbar Voltage: 13.335 V 000136 - Fuel Rail/System Pressure P0088 - 004 - Too High - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Mileage: 143873 km Time Indication: 0 Date: 2013.11.24 Time: 12:57:35 Freeze Frame: RPM: 703 /min Load: 33.3 % Speed: 0.0 km/h Temperature: 88.0°C Temperature: 39.0°C Absolute Pres.: 1020.0 mbar Voltage: 13.335 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09D-927-750.lbl Part No SW: 09D 927 750 GF HW: 09D 927 750 GF Component: AL 750 6A 1072 Revision: 00H64000 Serial number: Coding: 0000504 Shop #: WSC 31414 790 00001 VCID: 78F5F6390BC86A9 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4L0-910-517.clb Part No SW: 4L0 910 517 B HW: 4L0 614 517 D Component: ESP ALLRAD MK25E1 0010 Revision: 00H30001 Coding: 0082993 Shop #: WSC 31414 790 00001 VCID: 2953E37D80E2031 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0230 Revision: 09010701 Serial number: 10601500907432 Coding: 0000135 Shop #: WSC 31414 790 00001 VCID: E3CF3155224E191 Part No: 4F0 910 131 L Component: FBSAUDIC6 EZS H45 0080 Part No: 4F0 910 335 Component: FBSAUDIC6 KSG H27 0080 Part No: 4F0 910 220 G Component: FBSAUDIC6 IDG H01 0060 2 Faults Found: 00193 - Right Rear Door Handle Touch Sensor (G418) 011 - Open Circuit Freeze Frame: Fault Status: 01111011 Fault Priority: 3 Fault Frequency: 3 Reset counter: 12 Mileage: 142657 km Time Indication: 0 Date: 2013.11.16 Time: 14:24:23 00191 - Passenger's Door Handle Touch Sensor (G416) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00110111 Fault Priority: 3 Fault Frequency: 6 Reset counter: 54 Mileage: 142657 km Time Indication: 0 Date: 2013.11.16 Time: 14:24:11 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl Part No SW: 4L0 910 732 R HW: 4E0 035 729 A Component: Interfacebox H43 4610 Revision: 00000000 Serial number: 354JO077530251 Coding: 0002003 Shop #: WSC 31414 790 00001 VCID: 387536394B48AA9 Part No: 4L0 910 609 Component: E0380 BedienteilH01 0060 1 Fault Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 252 Mileage: 142648 km Time Indication: 0 Date: 2013.11.16 Time: 14:00:41 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4L0 910 043 HW: 4L0 820 043 F Component: KLIMABETAETIGUNGH05 0060 Revision: 00---012 Serial number: 00000000136958 Coding: 0786472 Shop #: WSC 31414 790 00001 VCID: E1C33B5D38520B1 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 J HW: 4F0 907 279 A Component: ILM Fahrer H18 0250 Revision: 00000000 Serial number: 4F0907279 Coding: 0114123 Shop #: WSC 31414 790 00001 VCID: 30650E19A338729 Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AU716 H15 0100 Coding: 00064792 Shop #: WSC 31414 Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0100 Coding: 00152619 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4L0 910 110 B HW: 4L0 035 110 Component: MP3-Changer H45 0390 Revision: 00045006 Serial number: AUZ5ZBG1233705 Shop #: WSC 00000 000 00000 VCID: 1E39C0A1C9ACF49 1 Fault Found: 02261 - Data Medium 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 7 Fault Frequency: 1 Reset counter: 252 Mileage: 142648 km Time Indication: 0 Date: 2013.11.16 Time: 14:01:39 Freeze Frame: Text: 00000000 ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl Part No SW: 4E0 910 593 M HW: 4E0 035 593 F Component: SDAR SIRIUS H07 0160 Revision: 00000000 Serial number: AUZ4Z7G0177746 Coding: 0000100 Shop #: WSC 31414 790 00001 VCID: 31630B1DA8327B1 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.lbl Part No SW: 4L0 910 655 A HW: 4L0 959 655 B Component: 73 AIRBAG AUDI8RH42 0230 Revision: 06H42000 Serial number: 0038QD0779B+ Coding: 0014131 Shop #: WSC 31414 790 00001 VCID: 2B5F19758A1E111 Part No: 4L0 910 339 A Component: BF-Gewichtsens. H03 0030 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 A HW: 4F0 953 549 C Component: J0527 0410 Revision: 00H04000 Serial number: 90055072620097 Coding: 0032242 Shop #: WSC 31414 790 00001 VCID: 2757E54596F6351 Part No: XXXXXXXXXXX Component: E0221 H01 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Cannot be reached ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.lbl Part No SW: 4L0 910 468 A HW: 4L0 907 468 C Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 1000D078038386 Coding: F7F7FE77767A0200 Shop #: WSC 31414 790 00001 VCID: 2D5B176DB40A1F1 2 Faults Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 252 Mileage: 142648 km Time Indication: 0 Date: 2013.11.16 Time: 14:01:50 02103 - Control Module 2 for Vehicle Electrical System (J520) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 43 Mileage: 142818 km Time Indication: 0 Date: 2013.11.17 Time: 19:15:16 ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 B Component: SG ext.Player H15 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2B5F19754A1E111 No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4L0 910 158 HW: 4L0 919 158 D Component: KLIMABETAETIGUNGH05 0060 Revision: 00---009 Serial number: 00000000136802 Coding: 0000006 Shop #: WSC 31414 790 00001 VCID: E8D52679DB687A9 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4L0 959 760 Component: Sitzmemory FS H01 0100 Revision: 00000000 Serial number: 00000000896401 Coding: 0082954 Shop #: WSC 31414 790 00001 VCID: E1C33B5D38520B1 1 Fault Found: 01446 - Sensor for Driver Seat; Seatback Adjust (G230) 005 - No or Incorrect Basic Setting / Adaptation - Intermittent Freeze Frame: Fault Status: 00100101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 43 Mileage: 142648 km Time Indication: 0 Date: 2013.11.16 Time: 14:00:41 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 M HW: 4E0 919 887 M Component: MNS US H50 1100 Revision: 00000000 Serial number: 313JS077527353 Shop #: WSC 44881 000 1048576 VCID: 387536394B48AA9 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 4L0 910 566 B HW: 4L0 907 566 A Component: J0769_SWA_MasterH10 0100 Revision: 00H10000 Serial number: 6PZ 009 014-00 Coding: 0010001 Shop #: WSC 31414 790 00001 VCID: 2D5B176DB40A1F1 Part No: 4L0 910 568 B Component: J0770_SWA_Slave_H04 0100 2 Faults Found: 16365 - Control Module - Electrical Error; CPU 2 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 159 Mileage: 64572 km Time Indication: 0 Date: 2010.06.15 Time: 21:18:15 16358 - Control Module - External RAM Error; CPU 2 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 162 Mileage: 64644 km Time Indication: 0 Date: 2010.06.16 Time: 20:44:25 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl Part No SW: 4L0 910 793 B HW: 4L0 959 793 B Component: TSG FA H12 0150 Revision: 00000000 Serial number: ˜ Coding: 0051915 Shop #: WSC 31414 790 00001 VCID: 2F670D65BE066D1 1 Fault Found: 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 252 Mileage: 142648 km Time Indication: 0 Date: 2013.11.16 Time: 14:00:40 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4L0-910-289.lbl Part No SW: 4L0 910 289 F HW: 4L0 907 289 C Component: Komfortgeraet H07 0050 Revision: 0050 --- Serial number: 01060591290000 Coding: 7632925 Shop #: WSC 31414 790 00001 VCID: 336F0115522E491 Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 1 Fault Found: 02103 - Control Module 2 for Vehicle Electrical System (J520) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 43 Mileage: 142818 km Time Indication: 0 Date: 2013.11.17 Time: 19:15:18 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4L0-910-223-BO.lbl Part No SW: 4L0 910 223 G HW: 4L0 035 223 D Component: DSP-High AU716 H03 0150 Revision: PROD_01 Serial number: 00000000044510 Coding: 0000026 Shop #: WSC 31414 790 00001 VCID: 2855E6799BE83A9 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 D Component: ILM Beifahrer H12 0100 Revision: Serial number: 00000000014523 Coding: 0012001 Shop #: WSC 31414 790 00001 VCID: DEB900A1092C349 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl Part No SW: 4L0 910 793 B HW: 4L0 959 792 B Component: TSG BF H12 0150 Revision: 00000000 Serial number: #g Coding: 0051915 Shop #: WSC 31414 790 00001 VCID: 2F670D65BE066D1 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000021 Shop #: WSC 31414 790 00001 VCID: 2953E37D80E2031 Part No: 7L6 941 329 A Component: AFS-Modul links H06 0002 Part No: 7L6 941 329 A Component: AFS-Modul rechtsH06 0002 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 S Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 388J 077651317 Coding: 0000002 Shop #: WSC 31414 790 00001 VCID: 31630B1DA8327B1 No fault code found. ------------------------------------------------------------------------------- Address 5C: Lane Maintain. Labels: None Part No SW: 4E0 910 217 C HW: 4E0 907 217 C Component: J759 LDW H06 0070 Revision: 00H06012 Serial number: 400207A1500094 Coding: 0000101 Shop #: WSC 31414 790 00001 VCID: 2045FE59F3D8C29 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4L0 910 181 A HW: 4L0 915 181 Component: J0644 BEM H12 0690 Revision: -------- Serial number: 00000000031964 Shop #: WSC 07322 444 84037 VCID: 254BEF4DECFA271 Subsystem 1 - Part No: 4F0 915 105 D Component: von VA0 2710151156 Coding: 344630393135313035442056413032373130313531313536 Shop #: WSC 31414 790 00001 1 Fault Found: 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 7 Fault Frequency: 9 Reset counter: 53 Mileage: 142818 km Time Indication: 0 Date: 2013.11.18 Time: 01:54:19 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4L0-910-795.lbl Part No SW: 4L0 910 795 B HW: 4L0 959 795 B Component: TSG HL H21 0150 Coding: 0051722 Shop #: WSC 31414 790 00001 VCID: 31630B1DA8327B1 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl Part No SW: 4F0 910 273 B HW: 4F0 907 273 A Component: Reifendruck 3 H05 0100 Revision: 00050100 Serial number: 00000600057218 Coding: 0062424 Shop #: WSC 31414 790 00001 VCID: 2241F451FDD4D09 No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A Component: SDS 3501 US H46 0630 Revision: 00000000 Serial number: 00000709030228 Shop #: WSC 12336 024 394758 VCID: 346D020957204E9 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer Cannot be reached ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Cannot be reached ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Cannot be reached ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Cannot be reached ------------------------------------------------------------------------------- Address 76: Park Assist Cannot be reached ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End --------------------------------------------------------------------- |
