vag errors help
Hi,someone scanned my a3 06 and found these errors
The oil level sensor i changed it to a new one but same error I dont wanna buy a air quality sensor if i dont have to, someone can explain me the errors meaning? I searches the net but nobody explains open or short to plus means Thanks 2 Faults Found: 00562 - Sensor for Oil Level/Temperature (G266) 008 - Implausible Signal Freeze Frame: Fault Status: 00000011 Fault Priority: 6 Fault Frequency: 254 Mileage: 56963 km Time Indication: 0 Date: 2012.10.08 Time: 02:43:00 00562 - Sensor for Oil Level/Temperature (G266) 010 - Open or Short to Plus Freeze Frame: Fault Status: 00000011 Fault Priority: 6 Fault Frequency: 1 Reset counter: 109 Mileage: 52793 km Time Indication: 0 Date: 2012.08.17 Time: 14:41:29 |
This is the second part of the errors
Thanks 2 Faults Found: 00819 - High Pressure Sensor (G65) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 145 Reset counter: 224 Mileage: 53208 km Time Indication: 0 Date: 2012.08.30 Time: 19:21:50 Freeze Frame: Temperature: 29.5�C Voltage: 12.90 V RPM: 0 /min Load: 0.0 % Load: 9.0 % 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 27 Reset counter: 224 Mileage: 52500 km Time Indication: 0 Date: 2009.04.12 Time: 02:44:21 Freeze Frame: Temperature: -50.0�C |
