AudiForums.com
-   VAG-COM (https://www.audiforums.com/forum/vag-com-94/)
-   -   Vagcom (https://www.audiforums.com/forum/vag-com-94/vagcom-134945/)
chefro Aug 2, 2009 07:15 PM
Originally Posted by dmaini (Post 1111169)
Yes you should use the 409 version only as the 805 version is locked down... and u need a h/W dongle for it to work
Thanks for replying, I appreciate your time.
(h/W is it brief for "hardware"?) From what I read, you refer to the 805 version that works only with a dongle, am I assuming correctly?
chefro Aug 2, 2009 08:46 PM
I replaced the "Labels" folder with the one in 805 and doesn't change anything.
It looks like no matter what you do or what version it is used, you have to license/register it in order to reset the service reminders...
Would you guys agree, or someone actually can prove that wrong?
https://i2.photobucket.com/albums/y1...equirement.png
So for a C4, besides reading the DTCs (limited modules) and probably coding of those 3 modules covered in the Audizine write-up, (belt chime, etc) the shareware version is worthless. I wish I could be wrong.
chefro Aug 2, 2009 08:52 PM
Scanning the car for about 1 hr got the battery discharged....LOL
I suppose that's a sign I got a crappy battery. At least something "good" came out of the cable usage...
chefro Aug 3, 2009 02:39 AM
I guess silence is a strong statement too concerning the C4s and VagCom.
It looks like I'll have to shed $ 100 to get a license, or just live (for now) with the reminder as it is.
Thanks.
xewax Aug 3, 2009 04:52 PM
Can you tell me how to change "Service in xxxxxxx km", I want to change xxxxxx kilometers.
nm3210 Aug 3, 2009 05:11 PM
chefro: I don't know about you, but i have to try a good 5-10 times before getting it to notice that i am using a 'registered' version using the method that i posted. I leave the command windows up (so i stack up like 5-10 of them all doing my bidding) and eventually it goes through. The problem is because of the timing of when it checks for it and when it copies them; i haven't bothered changing the timeout (which is set to 1sec), but that probably would help reduce the number of tries required.
Being that you can connect to your car, then you just have to try to get the program to work. Also note that you should run the .bat as administer because you are replacing files in program files. I'm confident that it should work because there just isn't any reason why it shouldn't. My friend's '98 A4 won't connect at all (he can look at one module), so at least you don't have his problem. So again: i get the message that says "...Requires VAG-COM to be Registered..." all the time, i just have to be persistent with the program (it's most definitely not perfect) and load it a bunch of times.
xewax: i don't think you can do that
xewax Aug 3, 2009 05:35 PM
Its possible to do that but I have lost a Link I found on this or other forum, I just cant remember and forgot to bookmark it.
nm3210 Aug 3, 2009 07:14 PM
http://forums.audiworld.com/archive/...t-2580854.html
porschefan Aug 3, 2009 07:49 PM
@Chefro
There is a script i found on an Audi Forum that allows the 409 to think it's registered, it prevents - or rather it constantly replaces the .bin files from being deleted, works like a charm.
nm3210 Aug 3, 2009 08:15 PM
Originally Posted by porschefan (Post 1111501)
@Chefro
did you even bother reading through this thread? good lord
