Originally Posted by nm3210
(Post 1111505)
did you even bother reading through this thread? good lord
BTW it works great cheers for that |
(Post 1111465)
chefro: I don't know about you, but i have to try a good 5-10 times before getting it to notice that i am using a 'registered' version using the method that i posted. I leave the command windows up (so i stack up like 5-10 of them all doing my bidding) and eventually it goes through. The problem is because of the timing of when it checks for it and when it copies them; i haven't bothered changing the timeout (which is set to 1sec), but that probably would help reduce the number of tries required.
Being that you can connect to your car, then you just have to try to get the program to work. Also note that you should run the .bat as administer because you are replacing files in program files. I'm confident that it should work because there just isn't any reason why it shouldn't. My friend's '98 A4 won't connect at all (he can look at one module), so at least you don't have his problem. So again: i get the message that says "...Requires VAG-COM to be Registered..." all the time, i just have to be persistent with the program (it's most definitely not perfect) and load it a bunch of times. xewax: i don't think you can do that I'll try your scripts method route over the weekend. By the way, I noticed it maintains the same port (COM2 in my case) everytime when I open it IF I plug it in the same USB port. I would assume I would just have to keep opening and closing the program until I see "Registered" under the "About" tab, without doing any further scanning or testing. Would this be a fair assumption? THANKS for your input! |
Try this.. works for me all the time...
http://forums.audiworld.com/showthread.php?p=15401625 Follow instructions carefully and use the above .bat file as that is the key to using the software |
So, is it possible to use vag com with 64 bit vista? Also, I'm pretty sure that I bought the wrong cable...the 02 a6 uses CAN? How annoying.
its not possible to crack it, i crack it and get that its registered and licensed, but when i try to use some functions i get that soft has to be registered, how is that possible?
Originally Posted by xewax
(Post 1115070)
I wish i could use all functions of this soft. Is that ok that i see black window when i launch cracked soft? like command prompt window.
I believe some one has bought full version of this soft so maybe its possible to upload one for all? :) |
Originally Posted by crazyguy
(Post 1113661)
I bought the one from Ross-Tech. Believe me I'm Cheap and I shop around but I have no patience for inferior B/S from parts that speak Chinese to my already effed up Vista. I need my crap to work out of the box. |
Originally Posted by the G man
(Post 1103422)
Do you guys start the engine before or after you connect the VagCom?
| All times are GMT -4. The time now is 05:43 AM. |
