VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
VagCom
Old Jan 30, 2008 | 08:39 PM
CIA's Avatar
CIA
Default VagCom
Hi,
I bought one of those cheap cables from ebay, until i get the money for the real one. I installed the program. I installed the drivers.
I have software 409. Now i ran into some problems. I have the impression that i do somthing wrong. On COM 3 the program display the follow message
Port Status: OK
Interface: Found
Type: Serial pass Through
Opto/Iso: No
Ross Tech design: No
So help would be appreciated.
Old Jan 30, 2008 | 08:42 PM
hiwords's Avatar
Default RE: VagCom
who did you buy it from?
Old Jan 30, 2008 | 08:43 PM
chaos92287's Avatar
Default RE: VagCom
it should look like this if the cable isn't plugged into your car
try switching it to COM 4 instead of COM 3 and it should fix it
Old Jan 30, 2008 | 08:49 PM
CIA's Avatar
CIA
Default RE: VagCom
I bought the cable ffrom szhid.
When i select the USB I have a message with Interface not found. Its something with the conection.
Do i have to buy the program from ross tech in order to make this work? I only DL the program from them.
Old Jan 30, 2008 | 08:51 PM
CIA's Avatar
CIA
Default RE: VagCom
I would buy the program in order to make this work. But i need to be sure that this cable will work on the car before i activate the program.
Old Jan 30, 2008 | 09:14 PM
chaos92287's Avatar
Default RE: VagCom
did you try switching it to COM 4?
Old Jan 30, 2008 | 09:53 PM
CIA's Avatar
CIA
Default RE: VagCom
yeah, no results
Is there a way to see(test) those COM ports somwhere?
Old Jan 30, 2008 | 09:58 PM
cantdrive55's Avatar
Default RE: VagCom
Try using version 311.2. Also make sure that your COM ports 3 and/or 4 are actually open and available.
Old Jan 30, 2008 | 10:09 PM
CIA's Avatar
CIA
Default RE: VagCom
how do i chack that?
Old Jan 30, 2008 | 10:24 PM
CIA's Avatar
CIA
Default RE: VagCom
In my device manager i can only in the Ports section only COM1 and LPT1...this means that i have no other ports availble?
