VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Vagcom help..
Old Apr 21, 2008 | 05:07 PM
Ericp501's Avatar
Default Vagcom help..
I just got a laptop with vagcom already installed.. I ran the codes and came up with 00140, 03242, 00101.. My car is undrivable, every time it hits 2,000rpms it looses all response and drops back to 500rpms.. The idle is very low and after attepmting to clear the codes nothing has changed, what do I do?!!
Old Apr 21, 2008 | 05:40 PM
Ericp501's Avatar
Default RE: Vagcom help..
my lemmiwinks also wont work..
Old Apr 21, 2008 | 05:50 PM
Ericp501's Avatar
Its saying "Timed out waiting for 0x55 character (bad ECU response)
Ugh this is so frustrating!!!!!!!
Old Apr 23, 2008 | 09:51 PM
Ericp501's Avatar
When I do a test it says
COM Port status: OK
Interface status: 0 - found, ready
Fast - synch Compatible: NO
When I try to actually run it and check for fault codes it says
No response from controller
Ive tried everything... Can someone please help me!!!!! I dont have a car untill I get it running right
Old Apr 23, 2008 | 09:58 PM
hiwords's Avatar
what version of vag com is it? also what cable you using?
Old Apr 24, 2008 | 08:18 AM
Ericp501's Avatar
311 and its an ebay cable.. I think my problem is the cable. I was able to scan a total of about 4 things, like central locks and other bs. But everything else I try just says "no response from controller" so the only thing I can think is the cable is crap
Old Apr 30, 2008 | 07:35 PM
Ericp501's Avatar
Well its not the cable.. I took it to Autospeed's shop and had my friend run their vagcom and the same thing happen.. So now what? any ideas? I just graped an ECU off ebay for pretty cheap then I'll just have that customed tuned. But if I can figure out what is going on with this ECU I can sell it with the GAIC chip in it
Old Apr 30, 2008 | 07:44 PM
chaos92287's Avatar
which cable are you using? serial or usb?
Old Apr 30, 2008 | 09:06 PM
Ericp501's Avatar
serial
Old Apr 30, 2008 | 09:45 PM
chaos92287's Avatar
there's a guy on Audiworld who had the exact same problem. he disabled LIFO plus lowered the baud rate and got it to work. which COM port are you using? serial ports are usually COM 1 but to make sure go into the device manager and double check the serial connection is the same COM port you are using to connect to the VAG software
here's the link to the thread (if you can understand AW's retarded forum) http://forums.audiworld.com/vag/msgs/6289.phtml
