VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
VagCom- No Response from controller
Old Sep 19, 2009 | 03:28 PM
duderseb's Avatar
Default VagCom- No Response from controller
Hi guys, I'm trying to get into the 01 Engine Control Module in VagCom 409-1 but every time I try I get an error message that says:
"No Response from Controller!"
I've already got the (alpha-bid) cable connected with all drivers downloaded and the correct COM Port being referenced between VagCom and the Device Manager with Vag saying successful every time I test it. I also tried with version 3112 with the same exact results.
Help please???
Old Sep 19, 2009 | 03:37 PM
Mr. Phil's Avatar
did u get a real one or ebay one? ive heard some ebay ones dont work
Old Sep 19, 2009 | 03:43 PM
duderseb's Avatar
It's the eBay cable... And this is the second time I'm using it in the car, the first time it worked no problems, I was able to check for codes (as far as the shareware license allowed) without a problem. However, today it just isn't working, can't even check for codes again... I don't get it.
Old Sep 19, 2009 | 03:53 PM
Mr. Phil's Avatar
wow i have no idea then lol... u sure it isnt ur hookup that is faulty? i read alot on here that people say they cant get the scanner to hookup to their car... maybe ur connector port went bad?
Old Sep 19, 2009 | 03:57 PM
duderseb's Avatar
Well the little green light is on... And it's showing up on my Hardware Manager... I've also handled it with care... I read somewhere that changing the "Baud" parameter can help... Ever heard of this? What values should I try?
Old Sep 19, 2009 | 04:08 PM
ghost6303's Avatar
does vagcom recognize the cable when you go into the setup tab and click detect?
if no- you should google "how to change com port number"
if vagcom isnt recognizing the car- is your ABS light on? do you have an aftermarket radio?
Old Sep 19, 2009 | 04:15 PM
duderseb's Avatar
Yes it does test successfully and the COM Port is the correct one between VAG and my computer...
My ABS Light IS on (been on for a long time)... Does this affect the problem?
Old Sep 19, 2009 | 04:17 PM
duderseb's Avatar
Old Sep 19, 2009 | 04:31 PM
duderseb's Avatar
UPDATE: I've been sitting out here in the car just messing around and this thing gets more and more strange... For some reason I can get into the 56-Radio Control Module all right... Why the heck can't I get into the engine? I would understand that my car might not have every single module that VAG supports, but I'm sure it's got a 01-Engine... lol
Please help guys, I really need to get in here to clear and diagnose some problems so I can have a car once more.
Old Sep 19, 2009 | 04:55 PM
BaconBait's Avatar
Do you have an aftermarket radio? If so, disconnect your radio completely by disconnecting the wire harness. VAG-COM's are notorious for getting screwy when an aftermarket radio is involved.
