vagcom question
Ok so I am looking into buying vagcom but dont know what one to buy I was looking on this website http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM.
key-com or key-usb is the one that will work for your car, if you need it to work with newer model audis too, get one of the ones with HEX- and +CAN
if all you want to do is simple stuff like logs, buy a vag-com adapter off ebay for $20 and download the trial version of vag software.
the trial version lets you log blocks 1-25. the full version gives you access to blocks 26 thru 120 somthing. the full version also lets you adjust fuel timing and other things. if you are going to be doing in depth tuning of your car, definately go for the full version. if you just want to monitor basic stuff, do some logging, and pull codes, the trial version is fine. you do not get to monitor fuel trims in the trial version.
you adjust fuel trims with limmiwinks/unisettings and that only works on the 2000+ A4's. So an ebay cable will do that.
I ordered the key-usb and they stop making them and they sent me a hex-usb which has a faster sampling rate. Its going to be worth the extra $100 for the real cable and sw since you get access to everything and wont be out any money if you want more than what you have later
