VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
VCDS Lite (VAGCOM) problems
Old Aug 21, 2010 | 01:01 PM
exequiel3k's Avatar
Default VCDS Lite (VAGCOM) problems
Hey,
well, i've been searching the web for a fix, without success..
Anyways, i'll keep things short.
I have VCDS Lite and use it with a cable of ebay..
I don't have any issues reading the engine, instrument cluster, etc etc..
The problem is that it says "to many communication errors" when trying to read AIRBAG or Auto HVAC.
I really need to access the AIRBAG module to clear the codes because while fixing the wiggling of the passenger seat, I must of accidentally triggered the AIRBAG light because of the yellow cable wiring or something.
But, I can't access it to clear it, and i'm stuck with the dumb AIRBAG Light On while driving.
Any help would be appreciated..
Old Aug 22, 2010 | 12:49 AM
MetalMan's Avatar
Just out of curiosity, do you have an ABS module issue? I used to not be able to access my AIRBAG module in VAG-COM because my ABS module was inaccessible. Once my ABS module was partially fixed (it then was accessible) the airbag module was also accessible.
thomaseeTT
Mar 5, 2013 11:02 PM
Sheasta
Jun 30, 2012 05:15 PM
krazzz
Feb 21, 2011 08:41 AM
pbbg
Jan 12, 2011 12:13 PM
hauptjr
Apr 6, 2010 12:03 AM
