Problems with 2004 A6 SLine starting
Old Jul 11, 2008 | 04:09 PM
indika_00's Avatar
Default Problems with 2004 A6 SLine starting
After work I am heading home to find out why I couldn't take myself to work this morning. My audi has never had any problems and then this morning it just turned and turned and wouldn't kick over. Does anyone have any suggestions?? I chatted with the dealership and I told them it had plenty of gas, plenty of battery and it acted as if it wasn't getting spark. Any suggestions would help......Thanks.
Old Jul 11, 2008 | 04:27 PM
JETSPEED333's Avatar
SoCal Crew Member
Default RE: Problems with 2004 A6 SLine starting
what engine???
Old Jul 11, 2008 | 04:34 PM
indika_00's Avatar
It is the 2.7T Quattro
Old Jul 11, 2008 | 05:59 PM
SoCal Crew Member
is the car modified in any way?
first i'd check the fuel pump replay and fuse.... then move to check spark and fuel are there...
Old Jul 14, 2008 | 01:24 PM
Superdug's Avatar
SoCal Crew Member/White Devil
Agreed and if it is a 04 it should be the 4.2 motor right? I think you can check your fuel rail to make sure there is fuel there, then i would go into the plugs and plug wires.
Old Jul 14, 2008 | 01:25 PM
Superdug's Avatar
Also if you kow it is getting fuel you can pop off one of the plug wires and stick ascrewdriver in the end of the plug wire hold it close to something metal and see if it sparks good way to tell you still have spark.
wreksta
Jul 12, 2012 11:21 PM
Smokin Tubes
Feb 5, 2012 10:11 AM
Lickmstickmman
Jun 16, 2010 09:29 PM
park_357
Mar 1, 2010 11:37 PM
eugrub
Mar 31, 2008 11:13 PM
