Split seat bottom repair in Seattle?
My A4 B5 front seat has a huge split in the seat bottom.
Anyone has repair done at a Seattle area upholstery shop? I see you can get a oem cover for about $350. I've also looked at the local junkyards, but most of the seats I've seen are also split. Thanks. |
I can't give you a direct answer; what I did was swap a good passenger-seat bottom to the driver seat. It requires a little disassembly and some reassembly, and cutting a couple slits in the cover to fit the driver side.
Thank you for the suggestion in case I can find a passenger cover.
| All times are GMT -4. The time now is 03:55 AM. |
