18 inch BBS RGR for Audi A4/S4/A5/S5
7 Attachment(s)
In perfect condition. 2 with tires (Pilot Sport 235/40/18)
Starting from a billet of 6,000 series aluminum, or a special magnesium alloy, every BBS forged wheel uses their special multi-stage Die-Forging process which can require up to 18 millions pounds of pressure to produce. Every stage of production is optimized to help create the best-forged wheel in the industry. BBS forged wheels are not only light, they have been designed to optimize the stiffness to weight ration while providing the safety and long term durability expected from BBS. This BBS RG-R is a Die-Forged 1-piece Aluminum wheel. Key Features: 18"x8" - Set of Four Offset: 35mm Center Bore: 82mm Bolt Pattern: 5x112 Diamond Black Center Caps Included Set of Four 66.6mm BBS "PFS" rings included Requires Conical Seat Wheel Bolts Weight: 18.6lbs each For comparison https://www.ecstuning.com/b-bbs-part...r/rg705hdbkkt/ |
How much do you want for the wheels?
Looking for $1800
Originally Posted by gonnajump
(Post 1513520)
